Home-Made balance tack
Tudor
Hey guys.
Been occupied by other things lathely, namely getting an old lathe up and running here at work...
It's quite beat and abused but Its a high quality Hardinge lathe. I rebuilt the compound (which clips onto the dovetail way as it's a lower-end second-operation lathe) so it has limited travel. The angle scale (which is under the top of the compound and visible through a magnifying glass built in) was completely covered in rust and grease. Now it's visible... It came in handy to set ~2 degrees of taper for my tack! I also took the excessive lash out of the compound ways so they are nice and tight now. This is a sweet lathe with a 3-jaw chuck as well as an assortment of 5C collets. I learned from a master tool and die maker on the high end version of this- the tool room lathe, with a proper apron able to cut inch and metric threads. This is it's lesser cousin.
A brass rod was tapered as thin as I could and then finished with sand paper as it was deflecting from the tool of course and not cutting as it got thin... I pressed it into a 1" slug of aluminum. A bit of tubing to keep it safe and a recycled container and we are done!
Anyway, here's the tack:
  • 2 years later...
Thanks.
I think the tack is easier. Just grab the assembly with your tweezers and set it in place. It seems to just fall into alignment with the fork. That was the whole reason for opening this- I dropped it and it stopped, so I figured the balance wheel or pallet fork jumped. Pallet fork was fine, and once I set this in and lined it up, it started running before the screw was in.
This kept excellent time before it hit the floor and still does now, so no adverse effect to hanging it.
It was only hanging a few minutes. Just long enough to check the escapement function.
Overbanking can be diagnosed and fixed without removing the balance. Rotate gently the balance with a brass tweezer or wood, it will move one direction but having a firm stop in the other. Loosen the cock screw, lift a the balance rim a bit and rotate in the direction where it couldn't go. It will start running, tighten back, check on the timegrapher and if no more trouble job is done.
    • It's pronounced "bombay" like the city.  French for bomb is, 😄, bombe, pronounced the same as in English. Bombé, bombe.
    • That's a really good idea! I have a 3d printer, I think I'll design something that I can clip on to the edge of my desk to do the same. Thanks for the idea.
    • I looked up bombè, domed in French.  It's pronunciation is bomb, does a bomb (explosive device) get It's name from bombè? I know we're going off subject but it's interesting.
    • Okay, I checked with the fine folks at the McCaw Company, and they agree it's the correct crystal, and they have one in stock, so with that sorted time to get onto assembly. Starting by getting the spring into the barrel, which was a bit harrowing. It took me several tries to get it hooked onto my worn old winder arbor, but I did find a new use for the micrometer stand I just purchased. Carefully dabbed some Kluber P125 braking grease to the left of the divots around the barrel, and a little HP1300 on the floor of the barrel before popping it in--in case you haven't seen it, this is a great illustration I found somewhere on this site. You're not the boss of me, Bulova.   2172_Bulova 11AOAC 11AOACD 11AOACB.pdf Bulova_11 AOAC, D, B(1).pdf I got the train back in and it didn't seem as free as I'd like. Looks like the driving wheel with cannon pinion has zero end shake. That could explain the low amplitutde I started with. Now if you were me, would you push on the plate jewel or the bridge jewel? I've attached some extra pictures in case anyone sees something else I'm doing wrong here.
    • I have quite a few watch brands from all over the world. For some reason this Timex electric from 1979 is capturing my attention this week. I am not a particularly fond of battery operated watches or Timex, but this one is different for some reason. Post your watch in your collection that seems to draw you in more now than before...
