Thomas Mudge would turn in his grave
oldhippy
54 minutes ago, Lenj said:
All the time that I have been collecting clocks, this is one clock that I must say I do not like..I think they are ugly..
I like the proper antique Lantern clocks providing they haven’t been converted to anchor escapement, and not housed in some daft case.
Personally I'm impressed that he managed to make another clock about 200 years after he died. :D
I love the key handle, just like a cheap alarm clock and that the movement is French (If you believe the writing) I'm sure one of the greatest English clock makers wouldn't have a problem having his name applied to a French clock.
2 hours ago, Lenj said:
Looking at that movement, is that not from a carriage clock?? I know I keep on about Couaillet Freres, but is that not their markings?? around the winder with the 4 dots..???
Those markings are easy to fake.
It's pretty typical the Victorians where obsessed with reproducing the past, the lantern clock style had a revival in the arts and crafts period of design and the french produced a large number of clocks in that style the smaller ones using carriage clock movements in both timepiece and striking clocks. There where many quality English and German made examples that used double fusee movements such as Winterhalder and Elliot clocks.
These pastiche type Lantern clocks began to appear around the 1880's upto the 1920's but some manufactures persisted with the design up until the 1970's with smiths producing the "Knell Gwynn" lantern style clock in both 8 day and electric version.
A great deal more of these clock exist than genuine Lantern clocks.
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
