Hi, I am from Maryland
I have always wanted to learn to repair watches. I am finally taking the first step. I have received the videos from John Tope and they have given me the initiative to start with pocket watches. I need to start buying tools and I want to be sure that I get the right ones the first time. I would appreciate all of your advice. Thanks for having me here
Welcome to this friendly forum.
Dumont tweezers are the best 3C is a good start; these will handle most watch work, not hairsprings. As you are just starting out you will not want to work on them.
Various eyeglasses
A good set of watch screwdrivers Bergeon is one of the best. This nice set will last for years you can obtain spare blades. These are the type of tools I had. I only recommend tools I have actually used. You should be able to obtain all your tools from cousins.
https://www.cousinsuk.com/product/bergeon-chromium-plated-5-pieces1
    • Thanks, Jon Sounds like a plan. Obviously I'll have the face on so do you think gripping with the holder will create any problems, but I will check in the morning to see how feasible it is but I assume it only needs to be lightly held. As for holding the movement instead of the holder won't be possible in this scenario as one hand will be puling on the stem while the other pushes the spring down. That was my initial concern is how the hell can I do this with only one pair of hands. All the other times I've had to remove the stem hasn't been a problem, apart from the force required to release the stem from the setting lever, but now I need to fit the face and hands its sent me into panic mode. If it had the screw type release things would be a lot simpler but that's life 😀
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
