ETA 2836 runs and stops
Hello,
I recently got my hands on a used ETA 2836 movement from a Rado watch, I thought it would be a nice little project to get it to run again.
It is currently still inside the watch, but it has the following issue, it runs for mostly one minute, sometimes even up to 5 minutes, then it seems to get a lot of friction, and stops.
If it runs for one minute it stops in exactly the same place it started. If you give it a 'wiggle' it will run again for another minute.
I would like to know what this could be, and how I can fix it / what parts need replacement.
I am not very experienced in watch repair, so thats why I am asking for advice with the diagnosis.
I hope someone can point out what could be the issue!
Regards
Hi JJW, you should really introduce yourself first before asking questions.
It is impossible to say what the issue is until the movement has been removed from the movement and inspected. If it runs but stops then almost certainly it needs a strip down and service. During this process the fault (if any) will be found.
Oh my bad, I will make an effort into introducing myself later today.
My question was not, diagnose my movement and tell me exactly what is wrong with it, it was more asking for some general pointers on what could go wrong with these movements.
One thing I noticed that for a period of about 5 seconds where there is more friction, the movements makes a much more high pitch noise when ticking.
As I have already stated, it is not possible to give a definitive answer without a closer inspection. It seems to be binding on something ,could be lack of lubricant or just dirty. The movement will need to be removed from the case and inspected.
Since your brand watch is of some value, you should learn on something else before going to it without any experience or tools.
I've seen a few Rados on ebay which came from the Phillipines.
If you've bought one of those be prepared as they've usually lived a hard life and will need some work to get it running properly.
Good luck!
Anilv
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
