watch service includes regulation?
By watchweasol · Posted
Hi. I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt, long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved. Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice. We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it. The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car. -
I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
Haha. You're just in a wicked mood today John 😅 -
Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5 minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
