New Project: Bracket Clock By Bryson
rodabod
This has taken me so long! The clock workshop has been closed due to covid, so everything ground to a halt.
Anyway, I’ve re-assembled most of it for testing. Took ages to get striking adjusted so that that the gathering pallet locked promptly after the final strike. And also getting the run-to-warning adjusted.
Still need to soak test the going train.
Will do. There is some pitting left on the steel parts of the striking work, but I didn’t want to remove much material (plus you won’t see it once the dial is on). The curved steel parts I put in a tumbling machine as they were very rusty. The clock had been kept somewhere damp (perhaps a garden shed).
The fusee chains were also very rusty and seized, so I cleaned them ultrasonically in ammoniated oil-based watch cleaner. Then I soaked them in grease mixed with solvent which was then dried off. Time will tell if that is a successful method, but it’s a modern way of lubricating bicycle chains, so I thought I’d try it.
  • 4 weeks later...
Some more photos, including the dial-side striking work. I only cleaned the dial-side components since they are not normally visible and I didn’t want to remove any material. I did however dress the screw heads as some of them were very marred.
I’ve cased it now, but may take it back out to adjust the exact time of striking - it strikes at 5 minutes past, so I may un-mesh and slip the motion works slightly to bring it forward.
Its always nice that all screws are cleaned and polished. One thing I have noticed, its a good idea after fitting the steel pins for the ratchet wheels to bend them into an S shape this will prevent them from ever slipping out. You don't want them to give because the damage that will cause will be formidable.
