How bad is this watch?
Kilkmaru
Looks like a considerable amount of water damage, and  stem/crown is fused with rust onto the case. If the dial side shows signs of rust, that means its a nightmare underneath and its not worth the trouble--unless there is some personal value for you.
J
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
