Watch disaster.
Good morning everyone out there. I have had for years an old Borgel watch similar to the one found on George Mallory of Everest. which stops, ran  very erratically and was no use  at all. I decided to service it. I went through ALL the procedures but the HS was right over one side. The Trouble!. I tried to sort it with two pairs of brass  tweezers and the spring is a blue steel one. It went from bad to worse, worser and worserer !!. I am 76 now and am not really capable of re-springing a balance anymore as hand motor functions and eyesight are not quite what they were. It looks nice anyway now it is re-assembled. My first disaster as a Jobber for years. Perhaps I should stick to Quartz !!!! Has anyone experienced the like ?
Well we all have disasters from time to time, I have a nice Jaeger Lecoultre 1930's pocket watch that has a out of shape hairspring when I got it the balance staff was also broken, that I changed and it now runs and is very accurate but the regulator is set off the scale on the retard side it doesnt look good but runs fantastic hairspring work is the most nerve racking and hard things that you can under take on a watch so I always leave well alone if I can.
You don't say what the movement is in your watch even with very old watches if you can identify the calibre it may be possible still to get a balance complete for it.
48 minutes ago, jdrichard said:
I have had the same problem and it takes so so much patience to get a vintage hairspring working again. I don't like hairspring work, would rather make parts on a lathe.
Thank you, yes, tell me about it. I don`t like HS work either
 I am usually successful but not in this case. Good wishes, Mike.
Edited by ecodec
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
