  • Similar Content
    • By anilv
      Hi guys,
      Thought I'd share some pics of my Oris Big crown with pointer-date (circa 2009?).
      Simple classic design and quite in the spirit of the older Oris watches.
      The case back gives a good view of the ETA2836 inside. The red rotor was a Oris touch. The edge of the caseback has a coin-edged design, similar to the front of the watch. This improves the look of the caseback as the metal edge would look too big otherwise. Increasing the display window wouldn't work I think as that would only show the movement holding ring.
      The line is still pretty decent..
      And the bracelet is nice and supple.
      But the design of the clasp is a bit plain.
      Oris deserves credit as it was one of the brands which was instrumental in bringing back the Swiss watch industry back from brink of the abyss. In the late. 80s and early nineties, their classically designed watches using ETA movements sold well by focussing on the mechanical movements and using it as their USP. Their tag-line at the time was 'high-much', as seen on the rotor in the movement pic above.
      This watch came my way as a part exchange for an Omega Constellation. The previous owner had gotten the Swiss watch bug but as he got deeper into the hobby he started to appreciate other brands. To be specific, he was  getting into the 'manufacturer' brands as opposed to 'ebauche' brands. It's a shame as this watch is quite good as it is. Ah well, the previous owner should be into Pateks by now!.
      Anilv
    • By mjtaven
      Can't stop wearing it !
    • By Ajayel
      Yesterday my Oris watch hit a tiled floor when the strap pin broke and the back crystal popped off. Being in a rush , I quickly pressed it back into position and left it for later investigation.
      Today the crystal seems to be fixed in position, but I have no experience of removing or replacing these. Was a simple press of the thumb strong enough to do the job? How can I check, other then testing with my thumb nail. Are these a simple pop on fixing?
      Many thanks.
    • are we talking about round wylers?  the special crystols are hard to find. there were several colors.     vin
    • I'm going to have to do something. One decent desk lamp and bulbs high up in the ceiling are not enough for me.
    • You are most welcome.
    • Thats  a poser,  what I had fitted to the bench at on time was a four in line which used halogen bulbs the same thing uses LEDs now and fitting that up with some 2by1 and made colapsible so that it folds up. the multiple light array should go some way to removing the shadows as the lights strike at different angles,  if it has a decent base a G clamp will fix it to the table/bench, food for  thought.
    • Yes, something like that might do the job. In many ways similar to the goose neck lamp I’m looking at. If only I knew what I need. The light in the picture I posted is very good (not the small one), it’s the fact that it is slightly in front of me hence the shadows. I can move it right above what I’m working on, but again, there will be shadows elsewhere because my hand and head will get in the way. I’m starting to think that a floor lamp next or close to me will be the best solution, casting the light from opposite direction. A head torch would be perfect but I don’t want to sit there with it on for hours. When I look at Mark’s oiling videos (jewels) it’s so clear, yes it’s a lot more magnified than my 12x loupe but there are no dark areas.
