  • Similar Content
    • By anilv
      Hi guys,
      Thought I'd share some pics of my Oris Big crown with pointer-date (circa 2009?).
      Simple classic design and quite in the spirit of the older Oris watches.
      The case back gives a good view of the ETA2836 inside. The red rotor was a Oris touch. The edge of the caseback has a coin-edged design, similar to the front of the watch. This improves the look of the caseback as the metal edge would look too big otherwise. Increasing the display window wouldn't work I think as that would only show the movement holding ring.
      The line is still pretty decent..
      And the bracelet is nice and supple.
      But the design of the clasp is a bit plain.
      Oris deserves credit as it was one of the brands which was instrumental in bringing back the Swiss watch industry back from brink of the abyss. In the late. 80s and early nineties, their classically designed watches using ETA movements sold well by focussing on the mechanical movements and using it as their USP. Their tag-line at the time was 'high-much', as seen on the rotor in the movement pic above.
      This watch came my way as a part exchange for an Omega Constellation. The previous owner had gotten the Swiss watch bug but as he got deeper into the hobby he started to appreciate other brands. To be specific, he was  getting into the 'manufacturer' brands as opposed to 'ebauche' brands. It's a shame as this watch is quite good as it is. Ah well, the previous owner should be into Pateks by now!.
      Anilv
    • By mjtaven
      Can't stop wearing it !
    • By Ajayel
      Yesterday my Oris watch hit a tiled floor when the strap pin broke and the back crystal popped off. Being in a rush , I quickly pressed it back into position and left it for later investigation.
      Today the crystal seems to be fixed in position, but I have no experience of removing or replacing these. Was a simple press of the thumb strong enough to do the job? How can I check, other then testing with my thumb nail. Are these a simple pop on fixing?
      Many thanks.
    • Very nice! I have an old Miyota movement That needs a new home. You’re giving me ideas! Sent from my iPhone using Tapatalk Pro
    • That’s a great watch! Sent from my iPhone using Tapatalk Pro
    • Hello everybody. I lived in Texas 51 years before moving “up north” to Oklahoma last year. One of my passions is fixing things - working on the house, appliances, cars, trucks, motorcycles, lawnmowers, and anything else that needs fixing and I’ve been good at it except when it comes to watches - what a humbling experience. Googling “broken set lever screw 6497” led me down a trail that led to this forum.   For watches: I like just about everything regardless of cost. I have a 1969 Datejust that my grandfather bought new (my watch addiction started there when I was little), and a 1966 Datejust I recently picked up, an Omega AT, a few Seikos, a Vostok, a couple Citizens, an old Bulova, a few Timexes, and a wristwatch-from-pocketwatch conversion with a genuine 6498 movement. Like many of y’all I’m sure, I’ve bought and sold a ton of watches since 1985 and haven’t slowed down.   The embarrassing screw-breaking watch is a Panerai look-alike with an ST36 Chinese copy of a 6497. It’s cheap but I figured it was good to learn on. Water was getting in, and the set lever screw was stuck so I broke it trying to get the stem out. Broke the two stuck movement mounting tab screws also, probably due to the water. Got a new ST36 and broke the same dang set lever screw trying to replace the stem. Can’t blame the water this time. Had no idea a tiny screwdriver could deliver enough torque to break screws. The price of education... I need to enroll in a course and stop red-necking this stuff.   I have plenty ST36 parts if y’all need any -except screws....   Great to be here,   Bobo         Sent from my iPhone using Tapatalk Pro
    • Hi William, Welcome to the forum. Have been to Elvis and Dolly parton show at Grand ole opry.  Carried out research work in the Atomic City.    Glad to have you here with us. Best wishes. Joe
    • To find out if the slot is in the right place, get a piece of wood wide enough to take the movement, use a 3/8th inch bolt and cut a slot in the end to take the suspention spring, drill a hole near the top of the wood and attach the bolt with a nut. hook the pendulum onto the suspention spring, attach the movement to the board where the crutch is at about the middle of the slot on the pendulum, if the movement is working? the clock should work, attach the hands and see if it is keeping time, which I doubt as I think the slot is way to low, anyway now you have this set up you can just move the movement UP or down till you find the right place for the slot. You do not need to cut the slot while trying to find the right place,  just drill a hole a 1/16th of an inch wider than the crutch, you may end up with a few holes however when about in the right place then cut the slot an 1/2 inch above and below the hole, you can fill to holes or just buy a new pendulum stick.
