Making a New Balance Staff
I am making a new balance staff for an 18S Waltham. I think the balance is friction fit, however, my first cut 1.45mm was a bit too much and the balance fits but is not tight enough. I decided to leave a little lip so I can rivet it on as well (let's see how that goes:).19e641063037bdccd4915a9b3d110fc7.jpg
I then cut the hairspring part at 0.9mm and the pivot at 0.12mm; cut down to 0.2 and then reduced using a stone.340ec79722a14ba5793dcd25aded4cb4.jpg794b88d4633f64a93536885f947df1ee.jpg80cfa1740f9d9242fc38592996abddd7.jpg
I had to move the Steel Rod out as I had worked my way in too far with a failed first cut on the balance part. I then cut the roller table side and angled the largest diameter.cc224b5f9b19d0b548f1af438af261ca.jpg8f83637792b552e627499582f0045006.jpg353a66b0a9a69378452144001703a7b3.jpgb739e131bc6529a6b6c0a4698a2f3f5e.jpg
Tonight I cut the lower pivot.
  • Like 5
jdrichard, I've moved this thread to the appropriate section, please take the time to select when posting.
Sorry about that. Started off with the intent of just saying stuff and then got specific :)
Started cutting the bottom half of the stafffec3613fb1100133e6e509c36b76e017.jpgSized it against the original staffc8a4492c730fc047eb29e7b88831d1c5.jpgGraved it down to about 0.2 mm and then filed it down to size with a stone and oilc369a124f40a38fc5b14b4984a5e5766.jpgI then burnished itb938e4b2a0378ff62ed3b0f0ea299ec0.jpgThen i fitted the roller table to make sure the staff was the right size.f1228ce2ea5a7e4252a066f31e7168fd.jpgI then fitted the staf on its own in the movement to make sure the length was right and the 0.12 staff pivots fit into the upper and lower jewel. It was a little long so I mounted the staff in the lathe and tool a little off the top pivot.71f0378de6a5961a141be31dba7ca514.jpgI compared the two staffs2cdc381c778e45725efca60c783038f9.jpgI Then fit on the staff loosely and assembled the unit as a final check prior to staking on the staff.49133bd18092ccb9a57444c144413c4e.jpg0cc8729d462c861f793c94f9a3a856ad.jpgAll done for now. Tomorrow I stake on the staff and roller table and test again.
Finishing the staff and riveting on the balanceccb956c1a1b284fdeae1a36950b31190.jpgUsing the Jacot, trimmed a pivot down and burnished themfc17dc9a5a77c2386c7fcb7fcd784885.jpgLower pivot was still to wide so put it back in the lathe to stone it down to size.5bd036f83b780a3b612387648d684737.jpgAligned the Hairspring and punched it on.c4060ab491d1fd7f9cbfa195aa6b04aa.jpgb7f677328e37ff432c840ab7f8dd891d.jpgIt was complete and completed the install. Watch is currently running down with the new balance. Will completely disassemble and clean and oil and reassemble. DONE:)684a98a8be11c2dbbd8069dbb6f9cd07.jpg
Making a friction fit balance staff on a lathe is very tricky. As I was cutting a staff for a waltham, i took a little too much material off and the staff was not fitting completely snug.a9d69f9bd5de64ab6d13188f29501b25.jpg
So, i decided to leave a little lip so i could river it on.60ac02be4788ca27d6a060025354ec66.jpgd7700e74ead1db77bfff7dec29a34f7a.jpg
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
