Seiko 6349a weird seconds hand fault
Hi all, I have this seiko that I got as a non runner, I stripped it cleaned it serviced it and fitted a new mainspring and put it on an auto watchwinder and it ran ok for two weeks. I took it off and wore it then it started gaining time like 20 mins in a couple of hours and I have noticed that about every 10 to 20 seconds the seconds hand has a little spurt and suddenly moves on by 2-3 seconds hence the gaining time. I have never come across this before so any ideas as to the cause. Thank you in advance Tony
Does the 'spurt' occur at regular intervals?  It could be wheels binding due to a bent pinion.  I would look closely at the interaction if the pallet fork and escape wheel.
Anilv
Anilv
it seems to be as i say anytime between 10and 20 secs you get the little spurt of 2 to 3 secs, i think i will have to take it apart again and check the pinions.
4 hours ago, jdm said:
I can't know what is wrong with the mov.t but incidentally let me note that (at least) the dial fakeness sticks out.
i know the dial has been refinished the seller listed it as a repainted dial and i could see that anyway but i liked it so i bought it.
I usually remove the balance, give the mainspring a wind and see if the pallet fork snaps from side to side when helped with a oiler. Then I remove the pallet fork and check if the wheels spin true with no wobble. You can also observe endshake as well.
If the watch is very dirty a dunk in lighter fluid for a few minutes will help loosen the old oil. Remove day and date-wheels as well as any other plastic parts first.
The reason I do this first before cleaning is that sometime you find issues which render the watch not worth fixing unless you have parts. Nothing worse then cleaning a watch and then finding a fault which brings everything to a standstill!
Checking as you dismantle saves unnecessary work.
Anilv
Anilv
i am going to dismantle it again and check it a bit at a time, thanks for the tips.
tony
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
