feintaster tool .
rogart63
Well I have one and it is very useful and accurate the most useful function is the adjustable table for putting small parts on it makes measuring jewels easy, they can still be bought for around £350 new, so as long as its functioning £85.00 is a good price they usually fetch £150 to £200 its the sort of quality product you only need to buy once useful but not essential.
I have one that I don't use much, but it is very useful when I do. The table is something that is really needed in my view, I also have a bench micrometer with a table and I use this more than the feintaster.
What I like about this is the soft closing of the anvils, very good for delicate parts. £85 is a decent price if condition is good.
Stephen
I'd probably replace the whole base plate.. My feintaster looks the same, but with blue velour. I always had mixed feelings about the stuff, since it's a dirt trap, and I'm not sure if it's that great at trapping dropped parts (which I assume is it's main purpose).
I wonder what would work better as a replacement.. Leather, like you suggest? Some sort of silicone sheet? Chamois? Anything that stops the part from bouncing.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
