Making a New Balance Staff
I am making a new balance staff for an 18S Waltham. I think the balance is friction fit, however, my first cut 1.45mm was a bit too much and the balance fits but is not tight enough. I decided to leave a little lip so I can rivet it on as well (let's see how that goes:).19e641063037bdccd4915a9b3d110fc7.jpg
I then cut the hairspring part at 0.9mm and the pivot at 0.12mm; cut down to 0.2 and then reduced using a stone.340ec79722a14ba5793dcd25aded4cb4.jpg794b88d4633f64a93536885f947df1ee.jpg80cfa1740f9d9242fc38592996abddd7.jpg
I had to move the Steel Rod out as I had worked my way in too far with a failed first cut on the balance part. I then cut the roller table side and angled the largest diameter.cc224b5f9b19d0b548f1af438af261ca.jpg8f83637792b552e627499582f0045006.jpg353a66b0a9a69378452144001703a7b3.jpgb739e131bc6529a6b6c0a4698a2f3f5e.jpg
Tonight I cut the lower pivot.
  • Like 5
jdrichard, I've moved this thread to the appropriate section, please take the time to select when posting.
Sorry about that. Started off with the intent of just saying stuff and then got specific :)
Started cutting the bottom half of the stafffec3613fb1100133e6e509c36b76e017.jpgSized it against the original staffc8a4492c730fc047eb29e7b88831d1c5.jpgGraved it down to about 0.2 mm and then filed it down to size with a stone and oilc369a124f40a38fc5b14b4984a5e5766.jpgI then burnished itb938e4b2a0378ff62ed3b0f0ea299ec0.jpgThen i fitted the roller table to make sure the staff was the right size.f1228ce2ea5a7e4252a066f31e7168fd.jpgI then fitted the staf on its own in the movement to make sure the length was right and the 0.12 staff pivots fit into the upper and lower jewel. It was a little long so I mounted the staff in the lathe and tool a little off the top pivot.71f0378de6a5961a141be31dba7ca514.jpgI compared the two staffs2cdc381c778e45725efca60c783038f9.jpgI Then fit on the staff loosely and assembled the unit as a final check prior to staking on the staff.49133bd18092ccb9a57444c144413c4e.jpg0cc8729d462c861f793c94f9a3a856ad.jpgAll done for now. Tomorrow I stake on the staff and roller table and test again.
Finishing the staff and riveting on the balanceccb956c1a1b284fdeae1a36950b31190.jpgUsing the Jacot, trimmed a pivot down and burnished themfc17dc9a5a77c2386c7fcb7fcd784885.jpgLower pivot was still to wide so put it back in the lathe to stone it down to size.5bd036f83b780a3b612387648d684737.jpgAligned the Hairspring and punched it on.c4060ab491d1fd7f9cbfa195aa6b04aa.jpgb7f677328e37ff432c840ab7f8dd891d.jpgIt was complete and completed the install. Watch is currently running down with the new balance. Will completely disassemble and clean and oil and reassemble. DONE:)684a98a8be11c2dbbd8069dbb6f9cd07.jpg
Making a friction fit balance staff on a lathe is very tricky. As I was cutting a staff for a waltham, i took a little too much material off and the staff was not fitting completely snug.a9d69f9bd5de64ab6d13188f29501b25.jpg
So, i decided to leave a little lip so i could river it on.60ac02be4788ca27d6a060025354ec66.jpgd7700e74ead1db77bfff7dec29a34f7a.jpg
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
