Services
Pip
I’m practicing with this lovely old Services wristwatch. Disassembled, cleaned, rebuilt. It was jammed solid before with years of grime, now things move but it won’t work. Two things I need to ask:
1. Mainspring is set. Does this mean watch won’t hold any power or is it that I can’t get it to latch on the bridle?
2. I can get the balance to oscillate and the pallet fork to swing with it, but that doesn’t seem to make move the escapement. All the pivots appear to be located in their holes. What have I got wrong?
Thanks in advance.
39da8d8dfe0e447c14623a62387a0cee.heic
b68ae8c4a11f2a87ac4b479978851b39.heic
3111143b96f0c1cf414a986ac0f934ac.heic
I’ll get a new ms on Tuesday evening then when I meet with my sensei and see if that does anything. I’ll also get him to look at it, I think it may be pivot port wear as they are all steel. I’ll be back!
On most movements the barrel teeth are visible on the edge of the movement.
Shake the watch to set the balance moving and use a screwdriver to push the barrel along on the visible edge and see if the movement runs. What you are doing is simulating the power of the mainspring.
Pin-levers need more power than a jewelled lever movement.
Anilv
Edited by anilv
Thanks in advance.
39da8d8dfe0e447c14623a62387a0cee.heic&key=7b356050a3f0a3cadaaab277fa49c776dd5040f06cff8d77deb77503d5f1307d
b68ae8c4a11f2a87ac4b479978851b39.heic&key=0171f518a9a0080ab5c532e69d22018a133c18cc43d9da0a79f87409edcf8fa9
3111143b96f0c1cf414a986ac0f934ac.heic&key=3f579c21b5b6bf1a458ebf62ed53594cfc7776e0955f574d0f25210d5d2861ef
The only thing I can ad to this is I live in Daventry.....
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
