Hello from sunny Queensland
Hello,
I've been lurking a while and finally got around to joining.
Im currently living near Brisbane Australia.
Ex airframe / engine fitter with near 40 years working on military aircraft.
Semi retired due to illness and suffering from the apparently non existent age discrimination, be over 50 and dont work for 18 months and you'll find out it exists.
Anyway it's time for a new challenge, I've always been fascinated by mechanical things, hense my previous job and hobbies riding and fixing motorcycles and four wheel drives.
I also dabble in shooting, reloading and minor gun repair and maintain the local gun clubs clay throwing traps.
I also enjoy welding.
Anyway it's taken me this long to decide on getting in to fixing something as small and complicated as a mechanical watch when most of the stuff I've played with can be fixed with a calibrated technical tap from a 4lb hammer.
Looking forward to watching and learning.
Peter.
Hi friend in Brisbane,  All good wishes for your interest in watches. Yes, do watch Mark Lovicks video`s. He offers courses as well. Check him out and get a copy of Watch Repairing Manual. Fried and/or Practical watch repairing. de Carle.  Then some cheap watches to get the mechanically sympathetic touch and know how. Good wishes with it all. Mike.
Welcome here. You're totally correct. I won't go into the details of my experience, depressing stuff that is best left behind.
Quote
Sounds great. I wouldn't mind a ride up the Gold Coast. I should be able to borrow an old Ninja for swift transport, but can I stop at your place for 2 or 7 beers and crash in the backyard? LoL.
welcome to the forum;  you have the best experience that any mechanic can get.  think of disassembling a radial engine the size of a wrist watch.  this forum can direct you to the best tech, manuals (now it seems to be videos).  there are some tricky dissembles, like which one is "the master rod".  enjoy,  vin
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
