Viceroy Quartz - stuck button
p2n
I don't normally do quartz but when I showed my father a watch I'd done he dug this old Viceroy out of a drawer and asked if I could look at it, "Got sentimental value that" he said.
Oh well, it's full of gum, got a flat battery and a stuck button. I've blasted it in the U/S and the water was black when done lol.
I've not done a quartz watch button - how do I get this out and back? It looks to be a minute c-clip. If I push it off will I ever get it back on again or do I need a special tool?
P6160184.thumb.JPG.948668dfc8426dae5679a1dddd92f452.JPGP6160182.thumb.JPG.b29c5e42c87b37dabc73cbc56615d99a.JPG
You don't need any special tool . Put some Rodico in the bottom under the clips. then use 2 screwdrivers to press the clips of. That is the easy part. Clean the rod and maybe put a new gasket in. Harder to put back . i use a sturdy tweezer to press it back. But happens once in a while in flies away into space.  i have seen special tools that looks like a screwdriver with a slot in the middle . Much like a springbar tool.  To press the c- clip back into place.
1 hour ago, oldhippy said:
Proper tools should do the trick. That is the reason they are made.
While true I think a bit of pragmatism is needed. If I bought the correct tool for every job I did (watches or otherwise) then
  1. I would need a warehouse to keep them all
  2. I would need another mortgage to pay for them all
Yes quite right. I suppose it depends if you are a hobbyist or repairing and making a living. On the other hand, if you get quite a few with this problem it would make it easier for you. It might save you pulling your hair out. :D
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
