Older Vostoks
Got these older Vostoks yesterday. All not running but had easy problems to fix, luckily for 4 out of 9. One Amphidia and the rest Komandirskies. I love them, they're pretty reliable thus far.
I've been having a problem keeping the seconds hand in on a couple. Any tips? Is there a special way to make them stay?
Sent from my Z956 using Tapatalk
I'm guessing your movements are the same as my Amphibia, in which the seconds pinion is held in place by a weak cantilever spring.  Pressing the seconds hand in place simply pushes the shaft down against the spring so that the seconds hand doesn't engage properly on the shaft.  You need to brace the seconds pinion from the back to prevent it moving when you attach the seconds hand.  I just use my finger to brace the pinion but I daresay there are other more proper ways to do it.
Kayman is exactly right. Here is a photo of what we mean. The brass spring has, as you can see, a round-shaped end which has to be supported. I put a piece of rod in my mini bench vice and supported it on that.
Yeah i thought that would hold it but i guess not. Many thanks for the tip. Also i seem to have problems with the balance wheel stopping. The pivots look fine, is it just a jewel possibly broken?
I'm surprised at their robust and fairly accurate movement. Quite a bang for your buck workhorse. 3 are keeping excellent time and I'm having trouble regulating a few gaining 5mins/day at least. It's annoying there's no quick set date but i don't care. My morning isn't complete without winding these babies up. It's a successful thing when i wake up and they're (most of them anyway) are right around the exact time... It's a wonderful thing to fix these with your own two hands and see how reliable your work is.
Any guess on the date of manufacture on these? Obviously the Amphidia is pre-89 I'm guessing 70's/80's and the Komandirskies early 90's? I'm quite sure they're all 2414 movements too correct?
  • 2 months later...
@Mattaphysics: It's not until now that I see your post. Did you get them all working?
It's a bit hard to see on the pictures whether they are pre-1990's or after the collapse of the Soviet Union. Of all the watches it seems that the Amphibian has a bit more sought after dial and bezel, but this depends also on the condition and what's written on the bottom of the dials. CCCP is of course before the collapse, but then you also had the military issued watches (3AKA3). To make matters more complicated, mix in watch-soup the fake CCCP dials .......
If they are all hand-wound, the movements are 2409 (without date) or 2414(with date complication), not sure if the Amphibian could have the even older 2209 movement?
Anyway, they are all quite simple to repair....... that was also the general idea behind these watches. You have enough training material and eBay is full of spare-parts :) Some parts between the 2409 and 2414 are interchangeable, but some are (sometimes) not .... I think VWatchie wrote something about that .....
Edited by Endeavor
For the date change you first advance the time over midnight. To acheive the quickset you should alternate the hour hand forwards (between 1 and 3) and backwards (between 11 and 9 o clock)...
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
