Hi from Thailand
Ricardo
Brit expat here, living and working in Thailand. I have a Tag Heuer 2000 auto chronograph that has been in a draw for a decade after it stopped working after being dropped.
I should have had it fixed years ago but never really found any place here in Thailand that came with recommendations.
So recently I discovered this resource and Marks great youtube videos, in particular the 4 part service of the ETA 2892 movement, which has given me incentive to order a few tools and open her up and see if it is an economical repair or not. Perhaps I can send it to Mark for specialist attention?
I'll start a thread in the forum and hopefully get one or two questions I have answered!
Welcome here.
Since it appears that you never worked on watches before, I absolutely recommend that you will not try to repair your valuable watch by yourself. You have really too many chances to do even more serious damages that what it has now.
I don't think Mark is taking work at this time but you may ask him anyway by PM. There is another experienced member from Thailand but he has not posted in a long time and I don't remember his nick right now. The official service center is
T.S.L. International Co., Ltd.
159/33 Serm-mit Tower, 20 Fl
Sukhumvit 21 (Asoke)
Klongtoey Nua
Wattana
10110 Bangkok
Thailand
OPENING HOURS:
Monday to Friday : 9.00am to 5.00pm
PHONE: +66 2 661 7272
FAX: +66 2 661 7474
Hi Ricardo, your Tag is too expensive a watch to make a start on. Take the advice of jdm . You may have a HS problem or very likely a broken balance if the drop was hard. In either case if you are just starting then work on cheapo movements until you develop your Watch repair skills. All good wishes, Mike.
Edited by ecodec
Thanks for replies guys. Sending out for repairs in Thailand, not an option. too frustrating trying to deal with that kind of thing here. I might look up the service center in Singapore though.
I hadn't really considered this watch is valuable, poor exterior condition and broken. Only paid £500 for it in 1993.
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
