7s26 ticking too quiet for timegrapher ?
dreja
Hello,
I'm wondering what is your experience with a 7s26 watch, when you put it on the timegrapher ? Does the ticking sound have enough volume, to be picked up by the microphone ?
I'm using a standard Chinese timegrapher.
When I put the whole watch on the microphone (for eg. my SKX007 or my colleagues seiko 5), the microphone has difficulties to pick up the ticking sound. If I put on only the movement without the case, there are no problems.
So I'm wondering where could be the problem:
The spacer between the case and the movement is plastic, which "isolates or weakens the sound flow" to the case ?
As the crown is located at 4 and the case is not symetric. The problem might occur because the edge of the case is not symetrically pressed to the microphone ?
I don't have issues with other "low volume ticking" watches or with bare movements without the case. So I hope my microphone works ok.
Thanks
Andrej
That is divers' watch with a thick case and caseback, so maybe that is the reason.
However I have no problem at all getting a good signal on a closed 7S26-0020 with either a 1000 or 1900 model timegrapher.
Hello,
thanks for the answers.
I've got a Timegrapher No. 1000, about 8 years old. It seems, that there are at least 2 versions of the No. 1000 model. The difference can be seen, when you switch on the display:
1st version shows the daily rate only on the top of the screen.
2nd version shows the daily rate also on the main screen in 4 different horizontal display sections.
I have also noticed that there are 2 types of microphone stands. One stands is more rectangular, while the other is more circular.
If you look at the back, there are two versions of Frequency calibration connector. One has a female BNC connector while the other has a usb square connector.
I've got the first version with a BNC connector and a rectangular microphone stand.
Unfortunatly my version has not the ability to adjust the microphone gain. The up/down buttons change only the contrast (both in capture mode and while stopped)...
Andrej
I agree it's probably just the thickness of the case although there may be a method to adjust the sensitivity.  I've done some Seiko 7002's that had pretty thick cases and found that taking the case back off during testing was an acceptable workaround.
8 hours ago, Pip said:
I think you can only adjust the mic gain on the 1900 version.
Yes, and on the 1000 model also as mentioned above.
However, using either model I have cheched literally hundreds of 7S26 watches with all types of cases and never had to adjust gain in order to pick a good signal.
Oh, I'm probably wrong then as I thought you couldn't adjust gain on the 1000.
As an aside I've not had issued picking up any ticking and tocking from diver cased watches either so maybe it's a mic problem.
Thanks for all answers, I have found the issue :)
The problem was, that I have put some Tesa adhesive tape on the one microphone's plastic part. I did this to avoid scratching the watch - without the protection tape I could see (with loupe) the small marks on watch case.
Without the protection tape it works ok :) Instead of the tape I can put a piece of paper or even a paper sticker (as on the photo) between the watch and microphone.
Very good, you're treating a $200 watch same as $2,000 one. Which can be justified by the OCD attitude of some owners.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
