My opinion on automatic cleaning machines
jdm
I fail to understant what an auto machine does better than manual or U/S cleaning. All what it does is heating the fluid and doing a little of shaking, plus of course chaning jars for you, oh the solace.. No doubt looks impressive to show off.
When I was, a watchmaker, I would clean many at once in an auto machine. Never need to watch and move the thing from one jar to another. It gave very good results. It left me time to get on with other things like cleaning the cases or fitting a new glass. Or if I felt like it a walk round town, come back in say 20 minutes and its waiting for you. After having an automatic, you will not want to go back to a manual one.
Agree with oldhippy. I miss my L&R varimatic a lot, cleaning was an absolute breeze.  It is broken & I will have to fix it myself (when time).  I now use a Indian made cleaner (Janter Pearl)  which surprisingly gives great results. But it is manual and is just not solidly built. The cleaner oldhippy has found is a lovely machine but I have not got a limitless budget.
Now when you look at the audience of this forum 70% are hobbyists than never work on more than a watch at the time, and never rush things. For them, the money and space taken by an auto machine is better spent elsewhere. Add that these old device have an habit of breaking easily (as the many threads here demonstrate) and there is only one guy in the UK that will will wok repair them, and you have another potential headache saved.
I agree. However I do find the ultrasonic cleaning method time consuming and inefficient. The parts seem cleaner and are dry when the machine has finished when using a pro machine without any fuss. It is down to budget and space.
Cleaner than from an ultrasonic machine having been just shaken a little? Sorry, that is hard to believe.
And since oldhippy likes to share Ebay links for these machines I have merged these threads to keep the discussion in a single place.
5 minutes ago, clockboy said:
The L&R varimatic not only washes the parts it also ultrasonic cleans as well. The parts come out clean and sparkly with a breeze.
I have looked at the L&R website and looks like they have dropped the automatic jar changing and are producing only U/S machines. http://www.lrultrasonics.com/industries/jewelry/
Maybe the professionals have found having to change solutions manually is not that a big issue after all.
I was told by the guy who re- furbed the L&R that the vintage machines Ultrsonically cleaned in all three jars but the new L&R’s only ultrasonic in the first jar. Changing the fluid was not an issue as it lasts for approx 30 watches.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
