Elma Watch Cleaning Machine
Funny I look most days to see what is about in watch tools and I know how cleaning machines can be pricey. A nice good cleaning machine is so much better then cleaning by hand which is something many on here tend to do. I have thought about buy one just to keep as a sort of memento.
23 minutes ago, jdm said:
Why? What it does that can't be done by hand or ultrasonic ?
If you have never used a cleaning machine you wouldn't know the difference. With a good cleaner and rinse the difference from cleaning by hand is unbelievable.
What if one uses the same solutions and give the jar a good shacking? Isn't just warming up and shaking that an non-ultrasonic machine do?
A cleaning machine also has a built in dryer it dries and doesn't leave any marks. Shaking parts in a jar you can do irreplaceable damage, not recommended.
A machine can keep your brain cells intact. Those who sits and cleans in the hand exposing themselves to a work environment like 50 years ago ... I could never dream of sitting and cleaning with toxic substances and solvents in front of my face ...
Why do the women sometimes are hard to be clever on? Think of all the times they have cleaned nails in acetone :-)
Sexism aside... I use isopropyl alchol in an ultrasonic cleaner far away from my bench. I don't think I'm placing my health at risk.
Great…. You mentioned just hand cleaning too ..... it is not healthy in the long run for those who choose this option!
I hope you saw my smile at the comment about nails cleaning
I simply meant "not using a specialized machine". I copied the term from previous postings. I also refrain from staying close to strong chemicals, it's common sense really.
On 5. november 2014 at 7:25 AM, SSTEEL said:
Me too, the end is in sight :)
Most of the screws and bolts etc need to be replaced, with the exception of the specialist screws/bolts, hopefully I can find these at my local hardware store. As you can see, many of rusted up, or chewed up.
15722540265_8326cc2345.jpgUntitled by Micky.!, on Flickr
Is the screws on the machine in inches or metric?
I have 2 of these type of cleaning machines in the loft from when I first started out at home and couldn't afford an automatic type machine, might have to dig them out and put them on the tinterweb, they are brilliant for someone just starting out. I used to set an egg timer so I remembered to move it round to the next jar and then put it on a socket timer when over the heater drying off.
On 22. april 2016 at 0:17 PM, oldhippy said:
Not a bad price its old but looks in good condition and not a bad price with a buy it now tag.
http://www.ebay.co.uk/itm/VINTAGE-WATCH-MAKEER-JEWELRY-CLEANING-MACHINE-/162046336739
The price of the machine is now set down. I suppose that it is 110V, otherwise I could be tempted. There must be someone in the US who can use this fine machine?
This is the one I had and they are absolutely wonderful. You will have to get the jars but they are available. Its an L & R Vari-Matic. Its a good price.
  http://www.ebay.co.uk/itm/L-R-Vari-Matic-III-watch-cleaning-machine-/361544953482?hash=item542dc22e8a:g:aOQAAOSwn1RXIqEe
Edited by oldhippy
These are cracking machines, one thing to be aware of is to make sure the jars are kept topped up with fluid, if you run them with not enough fluid in the jars it can burn the ultrasonic out.
there is a company in the uk that will do a full rewire, respray and replace the ultrasonics for a more powerful version for £1600. Sounds expensive but if you are after a cleaning machine that is upto standard for the brand accreditations then these are the cheapest way of getting a cleaning machine with ultrasonic that's  upto the standard the brands require.
That one doesn't have the transducer - but very true what you said.
I had two varimatics with the ultrasonic units but I prefer my elma super elite - it's manual but never have a problem with it, plus I get to keep the watch in the jars for much longer should I want to.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
