Old Hampden pocket watch
Have this old Hampden gladiator pocket watch from my grandfather . It was working  when i was a child. But  when i moved someone dropped it to the floor. Not me that time :)  Breaking something. Probably the balance staff. I have been wanting to repair it but don't know if it's possible. What do you think.  Looks like some parts are missing also.  Is it even possible?
DSC09884.thumb.JPG.5a959043bd97280bb0d382920fb012d6.JPGDSC09883.thumb.JPG.e3dd6c43907f5a0e5be448e20bcc3b0e.JPGDSC09882.thumb.JPG.0ae1f919c255ae37ffe1a5ee80d4c75f.JPG
Found this on youtube.
Edited by rogart63
I love Hampden 18s pocket watches & have four that I have restored & probably that many as parts movements. I don't want to know how much time & money I have invested in this beautiful coin silver favorite of mine
If it is very important to you for sentimental reasons I would say go for it.
Time i have . Is it even possible to do? It would be very cool to get it running again. What shall i look for. I have search for Hampden Gladiator . But there is a lot of different movements out there. Not sure where to start looking. I can service watches but have worked on pocket watches.
Balance is toast . So is the pallet fork. Some  screws are missing. And the regulator arm is missing to.
I think you need to start at the Pocket watch data base to get all the information about your watch. Go there and type your watch serial number into it . The site will tell you model, jewel count etc.From there you can search Ebay for the correct model , jewel count & with all the information you have.
I'm sorry if I am repeating things you know but I am just assuming, correct me if I'm wrong.
Here is a link to the data base. https://pocketwatchdatabase.com/
Now you can begin :)
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
