Minute hand problems....
For some reason I’m not processing this well. It’s been a long day. Correct me if I’m wrong. The canon pinion should make one revolution per minute, correct?
The cannon pinion is holding the hour hand
Sent from my GT-N5110 using Tapatalk
See below... I had to think about this a while - I always get it mixed up, but I still say canon pinion holds minute hand :)
Edited by sstakoff
32 minutes ago, sstakoff said:
Ha! The image I just posted shows the seconds hand attached to the third wheel! That's not correct - seconds are attached to the fourth wheel!!!
Yes and no.....
In a sub-seconds or a direct driven centre seconds configuration the seconds hand is indeed mounted on the fourth wheel. But in an indirect driven centre seconds configuration (which is what your illustration appears to be) the seconds hand is mounted on its own pinion which is usually driven by the third wheel.
This is a sub second. And to update, after staying up till about 1 o’clock this morning working on it, the watch is running better but still not perfect. Still the occasional stop but so far this morning it’s been running since 6:00am. Still not sure why.
See below... I had to think about this a while - I always get it mixed up, but I still say canon pinion holds minute hand [emoji4]
Crap, you are correct. It's the gear over the pinion that holds the hour hand...I should know this:)
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
