Help ordering the right Bergeon mainspring winder
23 minutes ago, PeterS said:
 If I have this correct, you will need the right hand ones for Swiss watches and the left hand winders for watches like Seiko.
Why getting left and right, in case the wise is incorrect all one has to do is transfer in a roundel and flip it.
Link to post
I didn’t realise you could flip it. In that case the more basic set would be good enough, buying additional sizes if required.
Link to post
This definitely sounds like the obvious thing to do and would save a lot of money, but where can we get the roundels? Searching eBay for "mainspring roundels" didn't come up with anything. So far I only have roundels for my three Unitas 6497/6498 movements which I got when I bought spares from Cousins. I guess I could buy spare mainsprings having the right diameter but the diameter info doesn't seem to be available (springs and barrels). I would assume experienced watch repairers to have "a ton" of them!?
Link to post
At the hardware store. And then drill to make of the right inner diameter. Or drill any metal piece that you like. It doesn't even need to be round outside, or the very exact diameter inside. Just a little bit smaller than the destination barrel.
Ingenuity beats big budgets and extensive tools sets, every single time.
Link to post
When can I borrow your metal drill and other required equipment? ;)
Link to post
You don't need a "metal drill" just an home use one. They start at euro 20? Drill bits are 1 or 2 euro each. Or use use a round file and develop manual skills. If you don't have these tools at home get them and I guarantee they will do good for watches and everything else at home.
Link to post
3
Thanks, I'll consider it an option! I would, of course, need a steady vice too, but I would assume they aren't that expensive. I'll look into it.
Link to post
5 hours ago, VWatchie said:
I realise my question wasn't adequately formulated, and I apologise for that. I'm a hobbyist and I'm still new to watch repairing (love it!) as I've only been doing it for a year or so, but the passion for watches and the fascination for measuring time I've had since I was a kid.
Never apologize for asking a question we are all learning here.
Did you notice when you read through all the answers that there were no absolutes? It's the problem with watch repair even if you had all the tools above they may not be adequate for every single situation. Which is not entirely a helpful answer for your question.
So if money is no object definitely buy it. The problem with starting watch repair is/and for all of us it's expensive to acquire every single tool so this usually means you have to compromise with, what do I need now to solve the problem. Or just really lucky purchases over time.
So if you're doing modern Swiss wristwatches you may not need a mainspring Winder at all because you purchase a new spring shove it in and that's the end of it. But either because you can't conveniently get a spring or the old spring looks acceptable then having some way to get it in other than the struggle of winding it in by hand would be nice.
Then before I spiral off into the mystery of winders from Bergeon You might want to look at the basic set 2729 Right handles only.
Then the other option is individuals but that brings up a problem and a mystery. To understand the mystery the first link is nice because everything is pictured you can see the numbers the descriptions and there's a second page. So all the bits and pieces are there all 17 sizes individually can be purchased plus additional ones specifically for ETA and Rolex. There is even a set specific for ETA and because they have specific part numbers I'm assuming that they're not the same as what's found in the standard set there's a difference somehow. Then a Winder for your Swiss pocket watch I assume you mean the older version that runs at 18,000 because there are two specific winders to correspond to the two versions of this watch.
http://www.julesborel.com/products/tools-mainspring-tools-mainspring-winders
http://www.julesborel.com/products/tools-mainspring-tools-mainspring-winders/bergeon-2795-eta-assortment-of-12-mainspring-winders-for-calibre-eta
http://www.julesborel.com/products/tools-mainspring-tools-mainspring-winders/bergeon-mainspring-winder-eta6497-98-2
https://www.cousinsuk.com/product/watch-bergeon-2795eta
Link to post
To help clarify a little, the roundels that @jdm refers to might also be called washers, the sort that would you find with the nuts and bolts and other fixings at an iron mongers or hardware store.
Link to post
On ‎6‎/‎24‎/‎2018 at 8:47 PM, clockboy said:
I have the Bergeon Winder 1/2 set but had to modify it to work. i found the hole that accepts the spring when winding galas too small. However if you see a Master craft winder I recommend you purchase.  See pics to see how it works.\
A set is now on auction on eBay! Despite your illustrations I really can't say that I fully understand how it works. Nevertheless, I'm sure I'd be able to figure it out (I have an idea). Anyway, what I don't understand is if these winders are variable or fixed in diameter? If fixed, what are the sizes? Sorry if my questions seem uninitiated. :unsure: As I've already stated, I'm still pretty new to this. Thanks!!!
Oh BTW, what would be a fair price?
Edited by VWatchie
Link to post
  • 2 years later...
On 6/14/2018 at 12:20 PM, VWatchie said:
Indeed! A surprisingly educational and clarifying illustration! Thank you very much!
https://farm1.staticflickr.com/876/42080422644_b9dc757f4e_o.gif
So, we now know that when buying a Bergeon mainspring winder, the specified diameter is the outer diameter of the winder's drum. Brilliant! :thumbsu:
https://blog.esslinger.com/how-to-wind-a-mainspring-with-the-bergeon-mainspring-winders/
Thank you all for posting this information. Above find a link to some more info on this.  I know it's been a while for this board. I hope it's okay that I post something I came across, relating to this topic. It gives a pretty clear illustration, which I also like for reference as a la old school manual as opposed to video which can be hard to follow if not well done and not always clear. Many I'm sure know of this company but for those who don't, Esslinger, has a lot of useful written and video tutorials such as this on their website to go along with the products the offer, I just stumbled on them, and haven't read anyone mention in a forum so I thought I would in case it's helpful in any small way. Disclaimer -  I have  no relationship with Esslinger, I'm just a customer but FYI  I've also found them to be super nice, responsive to customers for orders or just info about stuff. Best.
Link to post
  • Similar Content
    • By Graziano
      This is a great tool for tightening pipe hands on vintage watches and especially the centre seconds hands on 7750 chrono and reshape centre seconds hands on seiko 6138 and 6319 movements so you can repush hands on back at zero. Even short pipe. Just pick a collet, place it into the tightener and turn screw slowly, rotate hand and repeat. And presto you can now push tight hands back on. From .4mm to 2.6mm
    • By VWatchie
      Some time ago I bought a Bergeon micrometre (and a Seitz jewelling tool) to be able to replace damaged jewels. The micrometre works perfectly down to the exact hundredth of a millimetre but trying to measure my first jewel I bumped into a very unexpected problem; the height adjustable round table fouls the spindle (circled in red).
      I don’t think, or rather I hope, that the micrometre isn’t out of order and can be adjusted so that the spindle does not bump into the table. But searching high and low I just can’t find any documentation or user manual for this type of micrometre. Being a hobbyist having spent a small fortune on these tools, this situation is very frustrating.
      So, the question is, what can I do to adjust my micrometre? As I have no clue what the various parts of the micrometre are named, I have given the various parts in the pictures a letter (in yellow) so that if anyone who knows how do this (and takes pity on me ) more easily can guide me.
      Keeping my fingers crossed. Hard!
    • By Rexxus
      Hello,
      im excited to be part of the community! I’m in the process of buying some of the tools I’ll need to tinker with pocket watches. My goal is to be able to take apart, clean, possibly fix, and reassemble pocket watches.
      I’ve bought a gorgeous pocket watch from a defunked jeweller from the early 1900’s Michigan. I brought it to a 91 year old watch maker and he told me not to start with it. Good advice. He gave me grief in general, hooked me up with some screw drivers, a loop, and a working watch cleaning machine for $20! I’ve bought a pair of tweezers, watch repair kit, some dial protectors, oilers and am looking for the items below. Hoping you can help me out with what to look for and where to find them. Right now I’m using eBay for a lot of tools and want to manage costs.
      1. What 3 chemicals do I need for the watch cleaning machine? It’s not an ultra sonic or whatever, it’s the kind with 3 glass jars. Where should I buy them for shipping to Canada.
      2. What attaches to the rotating arm of the machine to go inside the glass jars? A tiny cage to put all the pieces in? Are they universal or do I need the specific one for this machine?
      3. Oil and grease. I will stick to pocket watches only and will probably buy elign, Waltham, vostok, and any other pocket watches between $0-$40. I don’t want to buy 19 oils at this point. The basics so I can clean and lube a watch without wrecking it. If that means correctly lubricating 90% of it with 3 oils, great. Moebius seems to be the most popular. Which lubes do you recommend? From my research it seems I need 1 grease, 1 high velocity oil, 1 low velocity oil
      4. Mainspring winder. I can’t tell what brand or size I need. It seems 9-15. Are there specific companies that only make pocket watch winders or does Bergeron make them for wrist watches and pocket watches? I assume both so how do I tell a winder from Bergeron works with one of the other as an example. Seller doesn’t always know.
      5. Does anyone have any suggestions for books about learning watch repair?
      6. The watch I have isn’t an elign for example. Its probably a stock movement of the time put into one of his pocket watches. How would I find the technical guide? Are there rules of thumb? Do you just google tech specs in general for each movement?
      7. I was planning on taking pics of my tools and watches to post on here in a different thread. Is that a good idea? What thread is best?
      Thanks a million and have a good night!!!!!
    • By marcoskaiser
      Hello all,
      I just got a K&D mainspring winder very cheap, but the tool is a bit stuck and the spring does not open when the ring is loosened. I would like to clean and oil the spring. Any clues on how to disassemble the winder? I don't want to ruin the threads turning the wrong way or using pliers...
      Thank you!
    • Or after watch Kalle's video do you just stop cleaning watches in the US cleaner if they are made from thin Aluminium sheet 😉 Paul
    • Hello, I got an old Orient Deluxe with an Orient 4951 movement in it. I tried to look on the web for technical documentation on this movement but I could not find anything. Please if you have any technical doc that will help me a lot in my project. Thanks in advance
    • Thank you everyone for your input. It is very informative. I haven’t actually tried yet to adjust the beat error closer to the zero reading because the watch is running so accurate at the moment. It has now been five days and the watch has only lost 14 seconds to date. Can I ask another question then please. If the watch is running so accurately (in my opinion) what is the benefit in trying to get the beat error back to zero on the time grapher. Will it damage anything if left as it is? Thanks again all for your responses
    • Is Kalle saying not to clean watch parts in that type of (powerful) ultrasonic, or not to clean them with ultrasonic at all? All high end professional watch cleaning machines have been ultrasonic, with or without agitation, since the '60s. I've have never, ever, had an issue from ultrasonic on watch parts.
    • I forgot-I've discovered luthier files do the same. check out: stewmac.com  they use them on guitar nuts and stuff and come in a greater variety and not as expensive as the material houses we're used to.
