Hello
Welcome to this friendly forum.
Does anyone service quartz movements the answer is yes? Some parts can be obsolete or the battery could have leaked and damaged the movement beyond repair. Then a new movement would be obtained. These days it all depends on availability
Ah ok thanks, do you know any good websites for spares? Most movements I'm working on are miyotas, calibre 2035/ gm10 which cost about £5 maximum. So I presume even if someone were to send it to the original manufacturer's they would simply replace the movement and call it a "service"
Many thanks.
Welcome Tinkerman, Yes, you can indeed clean and service them.  However Old Hippy is correct depending upon the economics and availability. The electronic`s are very simple but mainly not worth the trouble. The ETA etc: at the high end are however worth investigation. You will need some basic test equipment. For a start see the Witschi Quartz Watch Knowledge for Professionals !. I hope this is of help, Regards, Mike.
Hi Tinkerman, Quartz watches are usually replaced be cause they are usually very cheap and not really meant to be repaired.
Having said that some can be repaired. The problem is diagnosing the fault is not really easy without the proper electronic testing tools .
Good luck!
Anilv
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
