Elma Watch Cleaning Machine
Its getting exciting now Geo, I have finally decided to etch, and coat the casing parts with a few layers of clear lacquer, after all the hard work of removing all the paint, and all the wire wool, and sanding work, it would be a shame to hide it all under a colour paint :)
I have taken photographs of the wiring, so I know how to rewire it, I did initially plan on replacing the large speed controller, but I think I will reuse it as its still working, so too is the motor, and the heater, the latter looks newer than the other components, so I would imagine the heater has been renewed at some point.
Edited by SSTEEL
I am so impressed - it's going to be like a new machine.
Now I wonder - would it be beneficial to coat the inside of the drying chamber with that heat resistant car paint, the one you would use on an engine for example. Probably overkill?
Maybe even under the heating element too - to prevent corrosion?
Starting to think maybe I should of started a separate thread for my Elma Super Elite restoration.
Anyway, new varnish in, and final parts now after two coats, a final coat on everything, then will polish the parts to remove any overspray.
15607567849_a9bc0cc8c3.jpgUntitled by Micky.!, on Flickr
15607989078_c8c34f4425.jpgUntitled by Micky.!, on Flickr
15793391765_635f4b2fc8.jpgUntitled by Micky.!, on Flickr
15173955973_a11edd0493.jpgUntitled by Micky.!, on Flickr
15607570279_414f3e1580.jpgUntitled by Micky.!, on Flickr
15173440034_59b106f91c.jpgUntitled by Micky.!, on Flickr
And a few shots now the clear varnish has dried :)
15609339097_738cf6d1bc.jpgUntitled by Micky.!, on Flickr
15770825626_e2e2b0ca0a.jpgUntitled by Micky.!, on Flickr
15609661890_93c07e0047.jpgUntitled by Micky.!, on Flickr
15608676819_7899de3bb1.jpgUntitled by Micky.!, on Flickr
The cast alloy parts, although come out ok, they are not as glossy and smooth as the aluminium case parts, so will need a few more coats tomorrow.
15794505745_67e232b52f.jpgUntitled by Micky.!, on Flickr
15770829526_5d8ee02e71.jpgUntitled by Micky.!, on Flickr
15609098308_d64dfabaef.jpgUntitled by Micky.!, on Flickr
15175067273_d26cf5763d.jpgUntitled by Micky.!, on Flickr
And the base needs one more coat...
15794508715_542d01acde.jpgUntitled by Micky.!, on Flickr
15609347137_884263aecf.jpgUntitled by Micky.!, on Flickr
15794510935_b5178bbf1d.jpgUntitled by Micky.!, on Flickr
Edited by SSTEEL
Lovely gloss finish you have there Micky, when does assembly start?
Thanks, all being well rewiring will start next week, quite busy with work during the week, so only have time at the weekends.
I love how it is coming out! Great job!
Thank you :)
Thanks, the wiring looks like a nightmare, but luckily I was wise enough to take photos of the various wiring, and connections which should help the rewiring :)
Anyhow, some goodies in from Cousinsuk..
Complete basket, this is the alternative to the obsolete Elma item..
15812312405_15a73d4717.jpgUntitled by Micky.!, on Flickr
15627463660_2f33fce27c.jpgUntitled by Micky.!, on Flickr
Gasket for the Motor (Seals baskets in the jars, preventing spash-back.
15626912998_a1dbe93865.jpgUntitled by Micky.!, on Flickr
Heater switch..
15810428181_0655d289c5.jpgUntitled by Micky.!, on Flickr
And new bulb.  I was contemplating fitting a modern motor speed adjuster, and LED light but seeing as the old parts are still working, I serviced them, and they should be fine for some yers to come all being well..
15812315875_0c49552757.jpgUntitled by Micky.!, on Flickr
OK - I'm jealous, I want a blue basket!!! Mine is boring grey.
:D
Top tip: If you ever need more of the little baskets (you can never have enough IMO) then I usually buy them from this guy - quarter of the price of Cousins:
http://www.ebay.de/itm/Siebkapsel-z-B-fur-Elma-Reinigungsmaschinen-/141412294943?pt=Uhrmacherwerkzeug&hash=item20ecd4611f
Wow! Nice and professional! Micky that's one mean machine you are putting together! I bet it will be better than new! Keep it up, great job! If I were a watch I'll be anxious to get a bath in that machine!
@Mark: Hi Mark, nice link, how do they compare in size to the Bergeon ones? I'd like to buy a couple myself!
Edited by bobm12
Sorry Bob, but I never purchased the Bergeon ones so I can't compare.
Nice link Mark wondering if they fit the L&R
Yes - I think they do fit the six compartment tray.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
