Elma Watch Cleaning Machine
Its coming together ready for the final rewiring, I spent a couple of hours yesterday measuring all the fixtures, bolts, screws, washers etc, and managed to find everything I needed in stainless steel from one seller on eBay :)
Edited by SSTEEL
