Follow what Nucejoe has said. This spring is doing nothing where it is. It should be at the other end of the arrow under neath
Hi All I'm learning and have not yet tried oiling pallet stones or escape wheel teeth. I've read that Mark shows this in a video but I can't find it. Can someone point it out? Thank you Charlie
Finally, the parts have just about dribbled in. I'm awaiting only the replacement dial and it's on US soil, inbound to me from the port of Los Angeles. It might reach me by Friday. So far, the case has been stripped, cleaned and polished. I've replaced the stock bezel with an aftermarket coin edge stainless steel model. After installing a new bezel gasket and a green insert, it snapped into place easily with a press. Next, I replaced the original flat mineral glass with a double domed, blue AR coated sapphire version. I have the replacement movement (Seiko 7S36, 23J) ready to go with the exception of installing the hands. They finally arrived from Australia after being in transit 39 days. I'll show them after the new dial is fitted.
