Unusual key wind
TimFitz
I just finished cleaning & servicing this Waltham 18s 11jewl key wind model 1857 from a run production of 100. It took days to get the case all cleaned up,and it needed a balance staff &mainspring. Also a nice new crystal
What interested me in the first place is it has the key built into the crown so you don't lose it. Apparently it wasn't a popular option because it didn't last.
I bought it from a guy that didn't know of this feature or he would have charged me a whole lot more.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
