Mainspring arbour won't catch
Been trying to fit the mains spring on my Elgin B&B. I broke the last one.
I've hand fitted the spring but the arbour won't catch. A close look shows this seems to be because the hole in the end of the spring is further back on the new spring than the old one.
All these photos are the same scale. The red lines indicate the problem measurement - the old spring and the arbour match, but the new spring is bigger.
I can't change the new spring so is it acceptable to file the arbour to make that space a little longer?
Should work i imagine. But what to do if it doesn't work? Can you find a new arbor? That is how i usually think when i  modify parts? Can i find a new or used parts i go ahead and learn something on the way.
Edited by rogart63
I did think of that but I've still not found a good source of parts for these old pocket watches - I've only been watch bothering for 3 months.
I'm guessing there was no such thing as standardized sizes back then?
Could you remove some from the end of the mainspring. If you could reach down there with a file without damage anything else? A thick paper behind and file enough material to get the mainspring down in the groove. Can show you tomorrow what i mean.
52 minutes ago, clockboy said:
It's just the basics of horology you always just adjust/repair the faulty part. By altering the arbour (if it works) it will only work with that specific spring.
Thank you! It is important nowadays to repeat this basic rule now and then.
Frank
Any tips would be welcome. My needle file seems huge compared to the size of the spring.
You may have trouble filing it with a regular file being the spring will be hardened. Have a look at getting yourself a small diamond file. I've bought a couple and really do love them, but like most things the more you spend the better it will be. The $2 diamond files aren't really worth the time
Mainsprings are not fully hardened at the end; they are annealed. That’s why you can easily modify their profile to match the curve of the arbor easily. Either file or punch it. If you file it, make sure your file has suitable safe-edges, and modify the file if need be.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
