Help How do i Remove Battery
There is a springy lever on the right side between the battery and coil. It has a tiny protrusion that goes over the battery on that side to hold the battery in place. Carefully push the lever aside a little and the battery will pop right out. The left side of the battery is held under a shelf of metal. When you put the new one in, place the battery under the shelf and then move that lever aside to let the battery fall into place. Be very careful not to hit that red coil with anything. Many a watch have bit the dust when the coil is hit with a screwdriver that is being used to push that lever aside. Steve
Sent from my iPad using Tapatalk Pro
