Venus 170 problem
Hi everyone !
I got quick question about Venus 170 at first the hands are stiff to turn so I put oil on the pivot, and is trun freely , but now the gear probably hade to much lubricate and cause the gear to run free ( hours hand and minute not move) do I have to remove the oli by cleaning the gear or is maybe a different problem like loosen and need to tighten up ?
Thank you !
Those are 2 gears/parts one inside the other right ?
There needs to be a bit more friction between the two so that the gear that gets to turn the other gears that turn the hands will not slip.
Might be need to tighten up , will try that.
