Poljot 2209 "double gear"
1 hour ago, dreja said:
I have checked and unfortunatly  I don't see any groove :(
Much mistaken that for some other  similar construction. Vostok uses the same two wheel.  Best is to make it as clean and free running as possible. Put a tiny drop of oil between the wheels. very little is needed . Maybe some 9010 diluted with naptha will be okay.
  • Similar Content
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
