Eterna 905 parts
Have a Eterna 905 i want to fit in a Tank watch. It had a 629 movement from the start. But as i can't find any parts for that use it. Have tried to make a new balance but either my skills are bad or something else is bad.
The Eterna 905 is fine and work . So with a clean and some new oils and grease will be very good. There is one problem . The cannon pinion and hour wheel is to low. It need to have a cannon pinion of  at least 3 mm mine is 2,5 . Was think i could make one but not to the work that is needed .
Do you think a cannon pinion from a ETA 900 would work.
