Bent hairspring
All right then.I baught some watches for practicing and developing my skills.The watch that I opened up is a russian "Raketa" with 2609.i movement and after some examination I have find out that the hairspring looks a litle unusual to other hairsprings.I unmounted the hairspring from the balace cock and voila it is bent.
I don`t know how severe is the bending but the pined pictures will tell.Any advice or tip is appreciated for startig to fix this bending.
Thanks in advance.
This will depend on your skill. Working on h/springs takes a lot of practice. It is very difficult advising when its just a photo and you can’t see the thing at different angles. If it were me. I would start around the red arrow. You first need to get it on the correct side of the B/staff, and then proceed to shape it into the curl of the rest of the H/S. Don’t forget I cannot judge if it is bent high or low once it is the correct side of the staff.
That is badly damaged. Good for practice, but I'm not sure with my skills if I'd ever be able to get a satisfactory result from that. Metals "work harden" when you bend them, so it affects the characteristics of the spring, even if you manage to get the correct profile. It will be easier if you can get another god hairspring of the same type to compare to.
Hi,
Sorry for the long delay of the results, but I`m back. So far so good I made some effort to sort the bending out.It is not an easy work to do but I liked it. The hairspring is far from being ready to be remounted, it still has some distortions that need repairing.Any advice, opinion is appreciated.
Thanks in advance.
52 minutes ago, Andraska said:
This is a super video featuring a russian Raketa watch. Probably one day I master this technic. Thank you very much
Not sure how he even did it. Tried that but only end up even worse. Looked pretty dirty before so i reckon he maybe just cleaned it when he did that. It was a bad example and just put it up as a not to do and fun video.
Hi,
Back again. I come to a bottleneck in terms that I don`t know how to make the end curve. I made an imaginative sketch drawing on the picture taken of the actual balance bridge, "X" marks the maximum regulation point and thats where the end curve ends I think....:unsure:
Thanks in advance.
Hi,
This is the result of the work I did.I still have a lot of work to do the hairspring is twisted, not concentric maybe the watch will remain as a practice time peace.How can i upload a video?
Edited by Andraska
Just like any other file from the "choose files" link below, or upload on a video website and post the the link.
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
