Clock Quiz Made it a bit Easier
oldhippy
Here are 5 clock movements. I want the type of movement and the country that they are from. Be careful and study the movements because this is hard. One or two are not so obvious as you might think. With no answers it looks as if it is to hard. So to help you here is the list of countries. France, America, UK, Austria and Germany.
Well these are my thoughts guesses,
1, I'm not quite sure about this one but I think its a cuckoo clock movement which would I think make it the German movement
2, first thought's it looks like a french striking movement in layout but with none of the quality so maybe a German Hermle but they are mostly floating balance escapements, after a bit of reading I think this is a American Seth Thomas 8 day time and strike movement
3 Austrian or maybe German  striking Vienna regulator movement
4, This is a English Turret clock
5, French Morbier striking clock
wise1971 you are correct. clockboy you need to know your clock movements, go to the back of the class.:D
A             fusee cuckoo clock          Germany
B             Seth Thomas                      American
C             Vienna Regulator            Austrian
D             Turret clock                        UK
E              Morbier Comtoise           French
Looks like i made it to easy.
Well I wouldn't of got any of those correct other than I guessed number 2 looked like a French striking clock, but the quality wasn't there, so was obviously made elsewhere copying a French clock.
I do like it when you post quizzes like this as I do learn quite a bit
That's nice to know. I'll make up another soon.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
