  • Similar Content
    • By FredS
      Hello,
      I have a j810 movement that needs a stem and crown. Can’t find part numbers. Citizen eco-drive j810-s088232.
    • By Joshua
      Hey, so I have a question. I've got an Invicta dive watch with a NH35A movement here that whenever I unthread the stem and crown as it is unthreading the date starts changing. Once its unthreaded I can change it to the 1, 2 and 3 positions and set and wind it accordingly. How can I fix this and what is causing this?
      Yours truly, Josh
    • By Lorenz
      Hey guys, my name is Lorenz. I am an 18 year old electrical engineering student from Germany.
      I got this Breitling chronospace a56012.1 from my granddad and I want to repair it.
      Besides a slight clicking noise while turning the crown ( someone please let me know if this is normal ) it works just fine.
      My main problem is that the black color on the Bezel is worn out on some positions and I dont know where to find a paint that holds on the metal nor do I know how to paint it again.
      I have worked with watches already, I disassembled a mechanical movement cleaned and oiled it again so I feel pretty confident in doing this job.
      And I would also like to change out the crystal, does anyone know what size crystal I need for this watch?
      Thanks in regards for any advice.
    • By adsterb
      Hey everyone, I cant find out how to get this drown off and I've tried everything. The Miyota JS25 movement says PUSH and points to a hole which I've learned means this is where you press to reease the crown but I still can't get the crown out no matter which position the crown is in. I first tried with the crown all the way out then with it halfway in, then all the way in and haven't been able to get it out, please help.
    • Welcome and enjoy the forum.
    • Hello guys. This is my last project – Seiko 6139-6010 aka Bruce Lee. Watch is from ‘69and it is based on the 6139A movement. Nice shot for the 50th Seiko anniversary of first automatic chronograph development. So please see the pictures below from all restoration proces. It took me 3-4 evenings. The watch came to me as non runner. Crystal was scratchy with many chips. Dial was dirty and dusty with signs of water damages. Hands lost their lume. Day calendar was loosen and didn’t work properly. Movement was complete but very dirty and dry – there weren’t any residues of old oil in the jewels. Somewhere were signs of water flood. I dissasembled movement and I gave it a bath in ultrasonic cleaner then i’ve assembled and oiled movement. Star disk od date wheel was repaird with small amouth of resin glue. Movement had tend to stop sometimes. Inspection showed that the tiny chip on the bottom pivot of the escape wheel. It was hard to see it. After replacment movement ran as a champ. I polished the hands cause there was rust and gave them new lume. Dial was cleaned. I didn’t touch the lume on the hours indexes. I was affraid to screw up it. I think now it is quite good despite the fact that the lume does not glow. Orginal crystal was polished but I decide that in the future I will replace it. Case and caseback got some polish works only with polishing paste, not too much cause I didn’t want to loose the sharpnes of orginal edges – as usual I did it. Bracelet was matted with abrasive wool. Everything was mix up and combined and there is the result. After measurments on timegrapher and adjustment it is a nice timekeeper. An amplitude satisfy me as well. Now I am enjoy to wear it. Please let me know what do you think of this restoration project and about my works on it. I appreciate your comment and your spend time. Cheers folks     VID_20191016_170551.mp4 VID_20191017_195141.mp4
    • Thank you for your introduction and welcome to this friendly forum.
    • Thanks for taking the time to respond. I especially like the see through back.  Wear it in good health.           Best wishes
    • Setting lever screw broke on my Timex 24 movement. I have another working 24 but in need to install the setting lever and new screw which seems somewhat impossible. Is there an easy way to get the lever and screw inserted into the hole?
