Some Schaublin parts I made recently
measuretwice
I haven't been doing much watch wise, but lots of work on watch tools.
I ended up needing to make a bunch of parts for a lever action tailstock for a small Schaublin lathe.  I have the factory main casting and quill (the critical parts) but all the auxiliary bits are missing.  The lathe is a duplicate so fortunately I had a set of parts to copy from.
First is the tailstock drawbar.  Toughest part was it’s a 11.75 mm metric buttress thread.  For those not familair, look at the collet; the flanks are 45 and 5 degrees vs every other thread that is symetrical.  It took longer messing about grinding the tool than cutting the thread, but it worked out well – its for a W12 collets
Next up, is the tailstock lever.  Not particularly difficult, but man, it was a lot of whittling!  Files and die grinder mostly after roughing to shape in the mill.  The turned portion I did by measuring the existing one, making grooves every ½” to the right depth, then roughing and finally finishing by hand turning.  I stuck the dull end of a 1” boring bar out in front of the work grabbed a large radius nose tool (maybe 1.5” radius, ½” tool bit) in a pair of vise grips and went at it as you would with a graver in a watchmakers lathe.
Paint is sprayed via airbrush, with talc in it to reduce the gloss.  In the last pic, I have some touch up to do….the quills were slightly different dia so I had to grind a bit out of the inside so it would fit.
Its watch tool related, but for a sure little different for this site so thought you might find it interesting....now back to the salt mine!
Edited by measuretwice
  • Like 5
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
