Screwdrivers Choices
53 minutes ago, maclerche said:
 I also have the Horotec screwdrivers and I am very happy with them. In fact, I have all seventeen sizes. I have not seen other brands with seventeen sizes ...
What's the advantage of having seventeen size? I don't use more than three of the common sizes, but had to buy an odd size once to release a stem.
Screwdriver preference is quite a personal thing round here so good luck getting a consensus ;)
I’ve had Bergeon and wasn’t that happy with them so I got a set of VOH. Now they are amazing. Can’t speak for Horotec but I’d skip Bergeon for screwdrivers. Good luck
Thinking of upgrading my screwdrivers. So am about to buy this set https://www.cousinsuk.com/product/bergeon-stainless-steel-ergonomic-9-pieces-rs
But want some that has the same size handle as my chromium https://www.cousinsuk.com/product/bergeon-chromium-plated-9-pieces-rs
Have the newer ones with the darker revolving stand.
My opinion: just check if they are antimagnetic! This is probably one of themost relevant aspects. I have similar ones and they are not antimagnetic and one of them is always magnetized.  Searching data from then sent  links  is not stated that they are antimagnetic.
That is mostly down to the blades. Change the blades for som antimagnetic or stainless steel ones and you should have no problem with magnetic screwdriver. Or buy a demagnitizer.
I wondered as i have a Bergeon 5970 before.  And like the thicker handles on that . But would like to have a new set.  Sold my old bergeon 5970 with thin handles.
But did the order today so time will tell.
They do look very comfortable! Eventually I want a set for myself, but for now my A*Fs will just have to do?
Anyone having any experience with that "declafor alloy"? I believe a saw a pretty much “thumbs down” post written by Mark Lovick, no?
“The Bergeon ‘Swiss Made’ 100% anti-magnetic blades are made from a super alloy known as declafor. This material is softer than the hardened stainless steel blades that are supplied with other sets.” Link here!
Edited by VWatchie
I have the first link set posted (colored plastic ends) and I’m happy with them. Some magnetism issues here and there but they are a step up from the basic A-F set I started out with. I use a basic permanent magnet demagnetizer on them as needed.
If the body is too narrow for you, just run a layer or two of shrink tubing on them to “fatten” them up.
  • 6 months later...
Good deal on screwdrivers passed on.
I ran across this sale on individual screwdrivers for .25 cents each a while back, and where I had low expectation but thought I would order some to use as disposables when needing a good edge. What I found is that there actually quit good prompting me to order more.
They seem to be hardened and I haven’t tossed one yet. Fact is, I find myself reaching for these over the Bergeon which I paid over $20ea for.
Therefore, I am passing the find on to anyone needing a good eco screwdriver.
All the best, Will
https://timesavers.com/search.html?q=screwdriver&go=Search
PS: shipping was $3.50
Order Details:
  Quantity: 4
  Item: 2.0mm Flat Fixed Blade Screwdriver(33266)
  Unit Price:                   $0.25
  Total Price:                  $1.00
  Quantity: 4
  Item: 1.00mm Jeweler's Flat Blade Screwdriver (01322)
  Unit Price:                   $0.25
  Total Price:                  $1.00
  Quantity: 2
  Item: 0.60mm Jeweler's Flat Blade Screwdriver (01319)
  Unit Price:                   $0.25
  Total Price:                  $0.50
  Quantity: 6
  Item: 1.40mm Jeweler's Flat Blade Screwdriver (01323)
  Unit Price:                   $0.25
  Total Price:                  $1.50
  Quantity: 6
  Item: 1.20mm Flat Fixed Blade Screwdriver(33267)
  Unit Price:                   $0.25
  Total Price:                  $1.50
  Quantity: 4
  Item: 0.80mm Jeweler's Flat Blade Screwdriver (01320)
  Unit Price:                   $0.25
  Total Price:                  $1.00
                                               subtotal:         $6.50
                                                  total:         $6.50
Shipping was $3.50
My pleasure, but I would like to add, in addition to someone starting out, anyone can use them as disposables (a screwdriver you don’t bother sharpening) dropping them in the can and grabbing a fresh one when the tips break down. Main thing is the tips are hardened so they don’t bugger your screw and these appear to be.
Take care and Mary Christmas to all
So I decided to buy a set of Indian screwdrivers from cousinsuk awhile back:
https://www.cousinsuk.com/product/indian-stainless-steel-7-pieces
I'm now looking to upgrade my screwdrivers and I saw this on esslinger:
https://www.esslinger.com/reversible-blade-replacement-screwdriver-straight-tip-set-watch-tool/
They're the same style of reversible blades that the Indian ones have and they're made in France. Should I try fitting them with these or just buy a whole new higher quality screwdriver set altogether?
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
    • Mike if you wanna drop me your address I'll send you a strip of this cs 100 in an envelope . I'd like your opinion of its workability  The cs100 might be better carbon is 1%
