What is wrong with this.
oldhippy
The clock is much later than the 1860 Stated by the seller, it has a modern replacement escapement, the top of the clock although the correct style is not original to the clock it is a different colour to the rest of the clock, the case may be bronze but the top is brass.
The movement is modern the hands would not be push fit for a old clock they would be held by a hand collet and pin on a period clock
Its a bit of a marriage of parts looking at it.
wls1971. You have the two right answers. Replacement platform. The whole case is in fact brass and not bronze. Peanut goes to you. :D
You are wrong about the date. The movement is around1860. The push on hands are correct and are matching, the style is spade.
A big thanks to all for taking part. Next time I will have to make it harder.
I was more wrong than right, how would you know if a case is bronze as opposed to brass what would be the tell tale signs of a bronze case ? I am currently reading carriage clocks by Charles Allix and Peter Bonnert I shall have to study some more I have a lot to learn.
A picture would be the colour. If you had it to handle it would be the weight. Solid  bronze would be much heavier.
English Giant c/clocks that have the case made of bronze are a hell of a weight. I used to wonder why are they called c/clocks its because of their style. A petite lady would have trouble lifting one.
12 minutes ago, omx5o said:
You can learn a lot from these quizzes.
I was going to say that the key was missing. Not a major problem though.
I am glad you enjoy them. The key is an important item. Very valuable clocks that have their original key can add to their price. While we are still on the subject of C/Clocks the original travel case can also add to their value, so can the original glass panels.
Any part of a clock that needs to be replaced should be catalogued for the customer,  the old piece handed back. It is also a good idea to tell the owner to keep the old parts with the clock.
32 minutes ago, clockboy said:
Got me. However I did notice the hairspring seems to be sitting out of centre so I doubt if it is running that well.
I thought it looked pretty sick when you consider it’s a new platform.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
