Sourcing/making odd vintage acrylic crystal
By rjenkinsgb · Posted
Re. rust removal: I'm using a formula created by one of the science channels on youtube (Elementalmaker). It's cheap, not acidic and works in a similar way to evaporust, but seems milder. It has worked well on everything I've tried it with so far, with no detrimental effects. The formula is: Per 100ml deionised water; 5g Tetrasodium EDTA [from amazon or ebay etc] then enough citric acid to bring it to ~6.5ph, testing with ph paper, plus a few drops of washing up liquid / dish soap. I've only made one, 100ml batch so far and it shows no signs of stopping working, though it is starting to look a bit murky! These spring winding arbours were the worst rusted items I've put in it - they had quite heavy scaled rust patches; you can see the darker grey areas where the rust ate in to the metal, compared to the untouched areas. The small clock parts are unaffected by the solution, other than the rust having gone. (I've also used it on such as setting levers & other keyless components, that had quite significant rust from water ingress). -
No, the Peseux 7040 is doing very well as far as the rate (and amplitude) is concerned. The maximum delta measured was 20 seconds between fully wound, crown down (+8 s/d) and fully wound minus 24 hours, crown up (-12 s/d). Compare that to the ETA 2763 having a delta of over 80 seconds. What I was trying to convey was that I observed that the much higher amplitude of the Peseux movement during a 12-minute measuring period could momentarily fluctuate by 30° just like the much lower amplitude on the ETA 2763. I haven't studied the History graph on @praezis PCTM software for any other than these two movements but I wouldn't be surprised to learn that these fluctuations in amplitude during a 12-minute measuring period are the rule rather than the exception for all typical non-high-end-chronometer movements.
I'm presently using a cheap supermarket ultrasonic cleaner, with L&R #111 cleaner and #3 rinse solutions. I cut a bit off the bottom of an appropriate size plastic sports drink bottle, which is a perfect fit around the mesh basket I use (~65mm diameter). That allows me to use mostly water in the machine tub and cleaner or rinse only in the small plastic container. I keep the solutions that are still fit for use in small glass jam jars. I use the cleaner then two rinses, then the mesh basket balances on my bathroom radiator (once it stops dripping) to dry the parts with moderate warmth. Prior to that I tried just lighter fluid (eg. generic zippo fluid) and just soaking / swirling parts in the glass jars, but the movements did not run at all well afterwards, they were still acting gummed up. The proper solutions make a world of difference & the watches now work as they should! -
By rossjackson01 · Posted
Have to agree with you. Will not do another. Did not enjoy the time spent. However, it was worth it to know that I understood how to disassemble, look for defects, repair and then assemble. Timegrapher? No facility to alter anything other than the stud. Everything is metal to metal.
