Screwdrivers Choices
Bergeon does not manufacture they just rebrand. The "best" screwdrivers are supposed to be VOH from France. I have and still use a cheap seat of the "Anchor" brand and they work perfectly, just they don't have a stand and the smaller is 0.80.
The AF screwdrivers are very nice. Ball bearing ends and nicely weighted. These are made in France. The same item is re-branded by Beco which is a German company you occasionally see on eBay.
I'd say the tips are more important than the handles themselves; I use AF Swiss tips, and used to use these on an old Indian set which worked out well.
I use this Bergeon set, the Bergeon 30081-S:
but have been incorporating other models from the same brand as well as others from other brands, mainly AF and Horotec.
I'd say, if you go the Bergeon way, don't get the ones with the round top. They will roll and fall from the bench as soon as you forgot you left them laying on it. The AF and Horotec are nice. Some people prefer the Horotec to the Bergeon...I like them both about the same...Horotec has a nicer, more accommodating top that should be good for certain hands while Bergeon will accommodate others. AF is a compromise between them. They all get the same tips...which I use from Bergeon, both steel and non marking (soft material).
If you go the Indian or Chinese way, some may accommodate good quality tips...I did experiment that way but they were not exactly centered or had a fitting problem, so you have to be careful about which you choose being the quality so variable.
In fact, I went the Bergeon way after my first cheapo set and have never looked back...OK, maybe sideways since, as I mentioned, I got some other brands too.
I hope this helps.
Cheers,
Bob
Thanks for all the information everyone. I think I will go the Begeon way but try some others as well. And I guess you can never truly have enough screwdrivers, right? This set I'm looking at I like because it seems to have a good set up though not enough screwdrivers. I'm assuming the screwdrivers shown are some of the most used.
Well, that's a combination with the oil pins and the oil wells. It is a compromise to have an "all included" fixture on your bench but it would be limited to only 5 screwdrivers. If you always work on a certain caliber, then 5 is more than enough I'd say...but if you don't you will have to buy more different and same size. The reason is you must shape the tip of your screwdrivers according to the screw you intent to work on. So the same size might have to be adjusted to one type of screw and so on as needed. Example and clarification: Maybe the plate screws are 1.2 mm but the "groove" is deep and wide so one 1.2 mm tip is shaped accordingly. Then you have a 1.2 mm pallet bridge screw with a narrow and shallow "groove"...and now you will need to have another 1.2 mm screw driver shaped accordingly...or waist time either changing tips or re-shaping the same tip! And that "pretending" example is just for one movement. When you change movements the story would repeat!
That's why I took this example as a test bed for other screwdrivers' types/brands...one more way to "gain experience" one screwdriver at a time. :)
Yes, Oldhippy, I got those screwdrivers' too...and they roll! Well, maybe not as drastically as I put it but the other ones don't do that for sure and the shape of the top (and hopefully the bearings) are much nicer...but then again, yours are the "original" design and the other ones an "evolution" of that successful design I guess.
They are still made but they are the "bottom" of the line now, the ones I use is just a "step up" from them...and then you have the ones pictured with the oilers which are supposed to be a higher grade but I believe they don't have much acceptance (not sure). It is the next generation ones the real nice ones...but they are expensive and honestly I have none. It doesn't justify the investment.
Either way, they are all nice, quality, lasting tools that will do the job well, comfortably and precisely.
Cheers,
Bob
We were posting at the same time, Stuart! :)
Yes, I have a 3mm screwdriver (only). I'd say if my main Bergeon set is a 10, those are a solid 9...as ofrei rates them! :)
I just find their weight a little over my preference...or it is maybe because it is a large one.
Cheers,
Bob
5 hours ago, StuartBaker104 said:
I have this set and I'm very happy with them...
https://www.cousinsuk.com/product/af-swiss-stainless-steel-9-pieces-rs
That's the one i've got, not too expensive, good for beginners like me who are not sure if they're going to fail miserably or not. :unsure: I must admit that Bergeon set looks the bees knees, i'd almost want to put it on the mantlepiece as an ornament. B)
Edited by Daveb
I use the Bergeon 30081S  set as well. I thought this was going to be the tool I used the most so it justifies the expense... they look good as well.
Whichever you go for, make sure you keep them sharp, there is no point having good quality screwdrivers if they are not in good condition.
I work on current Seiko and practically use only two sizes. But even if working on more varied watches I can't imagine using more than four sizes frequently. However what one may need is two sets with different blade thickness, because Japanese screw slots are wider. Also popular soft tips to work when working precious movements to lessen chanches of lealing markd.
I just bought the Bergeon 5970 set from Esslinger. Very pleased with the feel and quality. As for them rolling off the bench, i tend to keep my bench level so as to alleviate the tendency to roll for any great distance. I had purchased a cheap set from India and they were a pathetic joke. The chrome was peeling off just sitting and the tips would fall out every time you picked one up. The set screws were all stripped from constantly trying to re tighten them. I knew better than to buy cheap tools, but wasn't sure at the time if I would continue with the hobby. The replacement tips for the Bergeon are cheap and one could resize them for any application really...easy enough to change.
Ron
This is the set I've bought at the HK fair ($20? or 25?). I liked the barreled handle in case I meet a sturdy bracelet screw. Tips are excellent but sizes were not marked so I put my labels on it. Also showing the ridged tablet I bought to keep tools in place.My other set (on the tablet) is from India, and I had no issues whatsoever with it .
21 hours ago, rodabod said:
Where does one find one of these ridged tablets?
You could go to a place that sells rubber mats? That you have in the industry . V-ribbed rubber mats? Just as an example? http://www.guldstrom.se/sv/utrustning-fran-usa/rubber-matting-v-ribbed-black
Available in different sizes and shapes . Round ribbed.
Edited by rogart63
Yes I use the French screwdriver set and it's excellent. You can replace the tips with Bergeron brand if you like to spend extra money, but these are fine for me.
JC
Sent from my SM-G925T using Tapatalk
JC
Going by price (three times as much) VOH is supposed to be "better" than Bergeon. But I'll probably never know first hand [emoji1]
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
