Portable DIY desktop workbench
jarz21
Currently having limited space to work on watches, I decided that a portable desktop workbench would be necessary for me. I was inspired by this blog post for a similar sort of DIY setup, but was having trouble finding good sources for the individual components. Instead I used the following parts (mostly ordered from Amazon but available at Home Depot and Target as well):
  • Carlisle CT121623 Café Standard Cafeteria / Fast Food Tray, 12" x 16", Gray
  • 1x IRIS Desktop Letter Size Medium Stacking Drawer model DTD-L (available in clear or black)
  • 2x IRIS Desktop Small Stacking Drawer model DTD-S (available in clear or black)
  • Velcro 90087 Sticky-Back Hook & Loop Fastener Tape with Dispenser, 3/4" x 5ft Roll, White
  • Everbilt #12 x 3/4in flat head phillips wood screws (SKU 284 773; from Home Depot)
I paid about $32 for all of the above. Interestingly, everything except for the wood screws was made in USA. The plastic drawers do come with clips that allow them to be attached together, but the connection seemed pretty weak (hence the wood screws).
To construct, I drilled through all of the holes on the bottom of the small drawers where the rubber feet would be pressed in (and ultimately ended up removing the Velcro you see in the picture below because I went with the screws instead):
Next, I applied a bit of Velcro between the front edge of the two small containers. This may or may not have been necessary with the screws, but I did it anyway!
To attach the two small containers to the larger drawer, I removed the top panel of the latter, marked where all of the feet align, and drilled some more holes so I wouldn't crack the plastic by driving the screws through it. You'll see where the two front inner holes interfered with molded plastic, so I didn't use screws there (also why I used the Velcro in the picture above).
The screws may poke through the holes somewhat, but they shouldn't interfere with the drawers.
Next I used a utility knife to shave the low feet off the bottom of the tray to make it smooth, then marked where it would be centered on the top of the small drawers. And in case you had been wondering, I chose to use the tray because it was cheap and had a decent lip around the edge to prevent things from rolling off.
I then cut some lengths of Velcro in half and applied them to the topside of the small drawers. When I first ordered the Velcro, I hadn't planned on screwing it all together. The idea was to make it disassemble-able, but I changed my mind. Alternately, the Velcro could be replaced with double-sided 3M foam tape (though that wouldn't be thick enough to bridge the front gap between the two small drawers in the second picture.
And now the final product, all stocked up! Esslinger's Watchmaker's Anti-Static Bench Mat Work Pad fit pretty darn well on the tray, with a little extra space around the edge to set things that might roll otherwise. The drawers have no locking mechanism, so make sure they don't slide open during transport. They do have some tabs to prevent them from falling all the way out, but that probably won't help much by that point. Final height is 7 13/16". The tray itself is textured, so a vacuum-clamp vise like the one in the blog post would likely not work.
Hopefully folks find this useful. If you want, you could always stack more drawers. I find this size to be work pretty well and easy enough to store in the closet.
Kevin
  • Like 5
Excellent work, this is the beginning of a slippery slope, temporary workbench will become a permanent one later on - even if it means putting it in the toilet !
They tray is a good idea for when parts roll off, I remember using the whiteboard to actually make notes about the watch I was working on.
Glad you liked the blog post, forgot about that setup , that started everything for me !
Jonathan
Sent from my ONEPLUS A3003 using Tapatalk
Jonathan
Thanks, Jonathan! I always appreciate a good DIY project, and yours was a very clever one that was just what I needed at the time!
Kevin
  • 2 years later...
Great work. I like that it's modular and upgradeable. And when you move on to something better, it can be repurposed.
In case you are looking for some elbow/wrist support, I discovered these accessory from Aliexpress.
The adjustable sofa legs and flexible led lights will be great additions for the future.
Great ideas for accessories!
Since building this portable workbench, I purchased a 46" Husky adjustable-height work table from Home Depot that I otherwise use to work from home. Managed to procure my grandfather's old Luxo L-1 lamp, and bought a clamp-on monitor holder to clear off some of the work surface.
I still use my portable workbench for its storage while I work on watch projects, so moving up was not completely moving on
