Pallet stone replacement
I spent two hours yesterday evening trying to replace the pallet stones in a Illinois Bunn Special 18s 21jewel Pocket watch to complete the tear down & cleaning and mainspring replacement .
I went to bed because I just couldent get the stones shellacked in. This morning on my first try, Success
I always find that taking a break from a job that isn't going well seems to do the trick . whether its watch repair or any other tricky job.
Tim
It's one of those jobs that takes a whole lot of patience & practice. Patience is a learned virtue that is worth it's weight in gold.
Making videos isn't something I do. I do however take lot's of photos for later viewing.
I find your picture quite interesting I didn't know a tool that I normally think of for roller jewels could be used for pallet stones. So normally when I'm doing roller jewels I like to have a tool that lets me hold the pallet stones flats with the fork. They make a variety of commercial tools I have a picture of one style. Or just a simple brass plate with holes in it can be used. Then a picture of the way I normally think of the tool you're using.
Thanks John - every day is a school day! I bought a tool like the former one for replacing pallet stones and found I couldn’t hold the staff in it, so made one like your other examples. Now I know what the first tool is for. Never had to replace a roller jewel, but all set now when I need too!
At least for inserting pallet stones are easier than roller jewel.  I have a link below the talks about the pallet stones. Basically clean the fork clean jewels make sure you get the right one Where it is supposed to be there different and make sure they're facing the direction they're supposed to be. Then apply heat touch the shellac it forms a nice shiny surface like the image below. Unfortunately they're probably not were there supposed to be. Which is why we use shellac it can be heated up and they can be moved around a lot. Then if you have lots of money picture of a nice tool that makes setting the stones absolute perfect.
http://raulhorology.com/2012/08/eta-6498-escapement-fitting-the-pallet-staff-and-jewels-setting-depth-of-lock-and-run-to-banking/
I use either one. This was better for taking a picture.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
