Third Wheel
Hi! I'm a newbie when it comes to all this but I've become really interested and been wanting to learn more!
So I got a question when it comes to the third wheel.
The slot, in the frame of the whole watch, for the third wheel is like, any other part of the watch, ridiculously small. So small that it's impossible to fit the third wheel into the slot! The top of the third wheel slides into the cover slot just fine but the lower end wont go in - so if I were to put it together it would only wobble instead of spinning in place.
My question is if it's a possibility that the lower end has been snapped off or something because I can't see how this would work. I found a picture on google and marked the spot where I suspect my pin has been snapped off. My third wheel looks just like the one on the picture.
@oldhippy I see! Well I thought as much! So this wheel is just trash then. Where could I buy replacement parts? Is the correct measurements all I need or are there specific types of wheels for a certain work?
I'm sorry for all these questions. Like I said - I'm all new to this!
By the way. Thank you for taking your time and writing a reply! :)
First you need to id the movement by its calibre and number. Here is a link that tells you what you need to know. Do not worry its quite easy. If you cannot find it just post a good clear photo showing the movement and under the dial side less the dial. Here is a link to popular suppliers in the UK, many on here deal with them as well.
Id site
http://www.vintagewatchstraps.com/movements.php
Watch parts site
https://www.cousinsuk.com/department/watch-parts
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
