Save my diver
Forg
9 hours ago, jdm said:
I've never seen these symptoms in my limited experience, I think that could point to an issue with the mainspring or trains mentioned before already. Remove balance and pallet fork. Give it just a bit a winding, it should spin free, and when out of power the wheels should move backward very briefly. If it does, there is probably no point in taking the train apart.
Forgot to add an important step. Before removing the pallet fork, need to "let down"  (unwind in a controlled manner) the mainspring. Search this forum or watch some of Mark's videos to learn what that means and how it's done.
anilv> Very clear, thanks for that writeup.
Precisions: the watch doesn't work for a few seconds when I wind it, it works (well, worked) while I'm winding it and stops immediately if I let go the crown (not a few seconds later). About the water, I don't think a flow of water entered the watch, that was probably just moisture condensing, indicating failing gaskets: I didn't clean anything.
manodeoro> Bonjour !
I do want to get some experience in horology. But only "some" experience, I'm not ready for a full service. Cost-wise, I didn't spend $50 in tools (I thank China) and some of them would be needed to swap the current movement with a new one anyway.
I'm not in a hurry, I'm enjoying other watches for the moment. The fact I don't want to service the movement has to do with skills (and lack of oil) rather than time: I want to make baby steps.
There's no power left in the main spring since the barrel is sitting on my desk. So, rather than opening it to see the spring, I should replace everything on the movement and remove the balance and palet fork and see if it winds and unwinds? Can I do that without putting the main bridge back?
No, you can't.
  • 5 months later...
Nouvice should exercise patience,  Anvil's suggestion is experejce based.Should have posted , follow as advised, may not be too late now either.
Thanks to masterwatch repairer on this forum who enjoy teaching their hard earned expertise, to the art ..You not only fix your watch but learn and gain confidence in watch repair.
I too be on standby to bug you with my wierd techniques. :stuff:
Regards joe
You said the watch "Ticks" while manually winding it? is that correct? as you know you can only wind a watch until full tension is reached on the mainspring. If you can wind this watch  endlessly I agree that the mainspring is broken. as for wearing a watch in the shower...... hot water causes rapid expansion of metal parts which old gaskets cannot compensate for.
  • Similar Content
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
