Eta 2824 issues
dreja
Hello all,
I have some issues with Eta 2824.
As the amplitude was low, I have stripped the movement and oiled it according to Mark's video on youtube. I used only Anchor universal oil on all necessary parts.
I manually wound the movement before assembling the date and oscilaltong weight parts. Everything was perfect (straight line, amplitude more than 300).
A week later I started the same movment again and the amplitude was a litle bit lower (about 270). I continued with other assembly (date parts, dial, hands). After assembly the day rate and amplitude started to oscillate (from -2 to +10 s/day and amp. from 190 to 230), while the beat error remained ok (0.1).
I disassembled the dial, hands and day wheel again, but the amplitude is still low.
I tried also installing another balance (working perfecty in another 2824 watch) but no luck. Also demagnetising does not help.
Is it possible that I ruined something while powering down the mainspring too fast?
Is there anything else to check ?
Please help...
So one oil for everything is that what Mark recommended?
Then anchor oil has some interesting properties. First Zero specifications as to what it is. Then at least in the past a lot of unhappy customers because it goes from lubricating to glue very very fast. But maybe they have fixed that by now?
JohnR275, thanks for the answer.
Sorry, I didn't explain properly. Mark didn't recommend Anchor oil in the video - he recommended other oils, and also different oils for different parts.
But I used the Anchor oil and I used it to oil all the parts.
Do you think that the main cause for my issues is the wrong oil ?
Thanks
Andrej
So exactly what you're describing is what other people have described lubrication goes bad superfast. Easy way to find out is take the watch apart and clean it again and find another oil.
So as a beginner the cost of watch oil is astronomically expensive. Do a search on this message board and you'll find a lot of unhappy people over the cost of watch oil.  On the other hand a little tiny bottle will last you for years. Then there really is not a universal watch oil good for everything. But knowing that it's not ideal but it will work you could go for a bottle of Moebius Synta-Visco-Lube (9020) Watch Oil. It's synthetic it has a very long life it's a little heavy for some of the balance and escapement but it will work.
Agree with John but considering the 2824 isn't, after all, a cheap mov.t I would recommend to use exactly what ETA recommends. I suppose that's 9010 on all jewels but pallet stones, where 941 should be used. And don't oil pallet fork pivots.
That will maximize amplitude & durability, for a total of GBP 30 before VAT it won't break the bank.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
