New (to me) tools, not sure what they are!
Vacherin
The first thing is like a pin vice in the centre, with marking around the edge, and came with a couple of pointy things in the box.
The second machine with the motor has a dial gauge for measuring the runout of small gears, and two levers for applying pressure to the gears, presumably to true them, and a loupe to monitor things. I am wondering why you need the electric motor with the dog drive to rotate the wheel though?
Once I know what they are called I can presumably google/search for info.
For the first tool the box looks like there's a label on the side is that a company name for instance? To me it has a vague look of something to do with balance wheels/hairsprings but beyond that. So if there was a company name who made the tool that would be helpful.
Of the other tool almost looks like something from a factory perhaps. It's far too fancy for a watchmaker normally unless the watchmaker made it.
For the first tool, which is about 1.25 to 1.5" wide, the label on the box side simply says: "3 Broches, Frs. 96.50". That is French I assume, and the price, of 96.5 Swiss Francs. There is no other writing on the box. I can't see a make on the tool its self. Perhaps that metal rod, which is one of 2, was one of 3 broaches that fit in the centre, although they do look too big and I didn't try to fit them as they looked too thick.
Looking at the second tool, it looks home made, the seller didn't know what it was. All I could think was that it is for truing wheels or gears? First you spin a gear wheel rapidly using the motor, and then apply pressure while it rotates, first from one side, then the other. Finally you check runout with the dial gauge. There are two arms which look like they are designed to push from either side.
I got a 3rd tool, from the same place as the first, which is an Olympus microscope with a heated element attached that you heat balance wheels with to "glue on the springs". It is made by Hormec. It is an older version of this, with interchangeable movement holders.
https://hormec.com/horlogerie-3/balance-wheel-gluing/
I was hoping to adapt it and use it as a bench microscope. I had no idea that anything was bonded/glued onto balance wheels. Perhaps they mean shrink fit or something. This came from the same source as the first item, a watch production facility that closed in the 90s.
Definitely isn't to glue anything to the balance wheel. As described in french on the datasheet is to glue the end stud (piton) to the hairsping (spiral), that is, Etachron hairsprings. It's funny that in Switzerland, a true multilingual country, sometime they couldn't get the correct english translation.
3 hours ago, jdm said:
Definitely isn't to glue anything to the balance wheel. As described in french on the datasheet is to glue the end stud (piton) to the hairsping (spiral). That is the way Etachron hairsprings are made. It's funny that in Switzerland, a true multilingual country, sometime they couldn't get the correct english translation.
That answers the question about the Microscope, thanks. Language wise it is like that sometimes in Switzerland. Crafts People here can be highly technical in their speciality, and not speak English at all. Then you meet a 14 year old that speaks 5 languages.
My French is terrible. I was thinking of reading the Daniels Watchmaking book in French, and then compare it to the English version when I get stuck. I need to force myself with something like that.
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
