Worn non jewel pivot holes
Hi Guys
looking to see if anyone has any advice or any ways of dealing with worn pivot holes.
Working on a 1885 Kendal & Dent pocket watch, I am fairly certain that pivot hole size relating in lateral play in the train wheels is causing the movement to stop after the main power has started to release from the main spring
Any words of wisdom greatly appreciated
thanks
The correct way to fix this is to broach out the pivot hole, fit a bush then re-establish the hole and oil sink. You will also need to refinish the pivot by filing and burnishing on a jacot tool.
You will most likely find guidance on the net by searching for clock pivot bushing. I know there are better links if you look hard, but here is a quick summary http://www.m-p.co.uk/muk/ryoc/doc_page16.shtml
I know that some would fit a jewel as it’s quicker and easier, and some would try and punch the edges of the hole to close it up. Neither would be my recommended option!
Thank you Stuart - most helpful indeed
In the day, to fit a Bushing or to close the hole with a staking set and broach out both had there advocates, with this type of movement.
Both methods lend themselves to an effective repair, obviously the latter being of far less cost.
Sent from my SM-T585 using Tapatalk
isn't it an issue locating the hole properly?  In that the above locates based on the existing hole, but if its worn its a bit elongated so its centre location, that a tool will follow, has changed slightly?
Edited by measuretwice
That's why you have to close the hole to less than the diameter of the pivot and broach out, keeping the hole as round as possible. This work is not fine horology. As Oldhippy would say " Its more like Blacksmithing. "
But you can also misalign when Bushing, requires a bit of practice.
The way to do it is by the means of a D cutter, if the hole has been elongated there will be half of the hole that has been untouched that is where you line up the cutter so the flat side of the cutter is facing the elongated part of the hole then the cutter will be centred correctly if you know what I mean that’s why the cutters like in a jeweling set have a flat face.
Apologies. On the latter method as mentioned I should of said ream out not broach, that's a bit misleading. Also advisable to use a Reamer when setting a new Bushing, rather than a drill bit. The chances of misalignment are greatly reduced.
Only animals use a drill bit, there certain tools for doing certain jobs.
Hi Guys
thanks
What you need is this lot
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
    • Welcome from a fellow Seiko enthusiast, there are lots of us on this forum.
    • Nickelsilver is right, movement diameter and keyless works ‘fingerprint’ are important for identifying movements. That said, this appears to be a 7 jewel version of the a Revue 30 movement.  A quick search with google turns up parts movements, and individual parts should be quite easy to come by.  Hope that helps, Mark
